1992 Civic Cx Buildup
Old Mar 16, 2005 | 01:39 AM
hbadge070789's Avatar
Default 1992 Civic Cx Buildup
Basically this is what I have got for a full out drag civic so far:
-Dart B20 226mm block.
-Eagle Stroker kit (makes it 2.2l).
-Clevite Bearings.
-Total Seal Rings.
-Fully Balanced Block.
-1995 GSR Head fully ported and polished, decked.
-Supertech Valves, exhaust .5mm oversized and coated with inconel.
-Titanium retainers and dual spring setup.
-Complete Peakboost turbo kit.
-Endyne pcv breather.
-Complete cometic gasket set.
-LS Transmission.
-Hondata S200 B with most all the options.
-1992 Civic Cx.
-Full Lexan.
-Completely Gutted.
-Aluminum dash.
ADDED:
-ARP Bolts everywhere possible.
-Custom 12 point cage.
-Slicks with drag rims.
-Suspension(any suggestions)
-Race Seat.
And I think that pretty much covers it. Obviously, I chose to build the engine first. Now I just need to know what else to do to the car. All I am asking for is some input on all the things that I still need. I plan on making at least 600 whp. Please, I don't want a flame war(enough already in colorado). Thanks for any help you can offer.
Modified by hbadge070789 at 12:26 AM 3/17/2005
Old Mar 16, 2005 | 07:48 AM
Honda Bull's Avatar
Default Re: 1992 Civic Cx Buildup (hbadge070789)
You'll need to do the fuel system (not sure if you're using a fuel cell or not), springs stiff enough for drag racing, and you may want to ditch the LS tranny for a B16 or Type R tranny (GSR would even be better). Slicks would be a definate if you want to go quick. Probably a 22-23". What clutch are you using?
Old Mar 16, 2005 | 10:11 AM
JSpin's Avatar
Default Re: 1992 Civic Cx Buildup (HondaBullSQ)
well get to it man............come back and show us some progress when you make some
Old Mar 16, 2005 | 10:30 AM
ndogg's Avatar
your gonna need to get a cage and/or tube out the car too. and 22~23" slicks aren't gonna cut it unless you are only making 300hp.
Old Mar 16, 2005 | 10:36 AM
Honda Bull's Avatar
Default Re: 1992 Civic Cx Buildup (ndogg)
Monkey poop. I didn't read the turbo kit. My bad. My bad. Yeah. Bigger slicks... 24.5 maybe.
Old Mar 16, 2005 | 03:02 PM
Adam F's Avatar
What class and what sanctioning body do you plan to run?
Old Mar 16, 2005 | 03:27 PM
Default Re: 1992 Civic Cx Buildup (Adam F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What class and what sanctioning body do you plan to run?</TD></TR></TABLE>
Sorry to sound like such an idiot, but I don't know.
Old Mar 16, 2005 | 03:46 PM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbadge070789 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to sound like such an idiot, but I don't know. </TD></TR></TABLE>
you might want to look into that first because none of the street classes allow lexan or aftermarket dash, or completely gutted. that means you will be running in a pro-class... unless you are running 8's and ****... good luck.
here is a good resource for the street classes:
http://fastestfwdstreetcars.com/
also, ditch that LS tranny.
Old Mar 16, 2005 | 03:58 PM
towvtec's Avatar
do u have any pics?
Old Mar 16, 2005 | 04:49 PM
Adam F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">
also, ditch that LS tranny.</TD></TR></TABLE>
If you run in NHRA pro class you cannot use the Dart block
racer4life
Oct 19, 2013 09:31 PM
Got_EF8
Jan 16, 2011 08:07 PM
vbherrera
18
Aug 19, 2006 05:05 AM
