Heat Cycling Tires?
Can someone explain the process of heat cycling tires? Recently in the Type-R forum it was mentioned that if you plan to track tires, especially street tires, that you should have them heat cycled in order to extend the life and reduce wear.
Thanks
Thanks
Heat cycling is when, before the tire is stressed, heated to a certain temp to "melt" the radials together better, therefore aiding to prevent premature seperation.
There is more on this, try a search of the archives...
In addition, the tread compound will gradually get harder, which leaves you with a harder/ longer wearing compound that regains it's grip once brought back up to race temp.
hehe, let me save the time to click a link. I forgot about that site!
As participation in autocrossing, track days, driving schools and road racing continues to grow in popularity, the tire manufacturers have developed unique DOT legal competition tires which feature very sophisticated tread compounds. However just like other high performance parts, these tires will provide more consistent performance and last longer if they are properly broken-in.
The first time a competition tire is used is the most important. During that run, its tread compound is stretched, some of the weaker bonds between the rubber molecules will be broken (which generates some of the heat). If the tires are initially run too hard or too long, some of the stronger bonds will also be broken which will reduces the tire's grip and wear qualities. Running new tires through an easy heat cycle first, and allowing them to relax allows the rubber bonds to relink in a more uniform manner than they were originally manufactured. It actually makes them more consistent in strength and more resistant to loosing their strength the next time they are used. An important heat cycling step is that after being brought up to temperature, the tires require a minimum of 24 to 48 hours to relax and reform the bonds between their rubber molecules.
Looking at the heat cycling system, it positions a mounted and inflated tire between rollers which apply pressure while the tire is rolled up to speed. It is very important to note that this allows heat to be generated as a result of deflecting (stretching) the tire within its normal operating range. There is no "artificial" heat added (no oven, no forced air, etc). Then they receive the stamp showing they are Tire Rack heat cycled.
Measuring the tread temperatures with a tire pyrometer we confirmed that in our controlled environment we were able to achieve appropriate and more consistent temperatures across the tire's tread without causing treadwear. All of these are significant improvements over heat cycling tires on our test track. And the 24 to 48 hour waiting period efficiently occurs while the tires are in transit to you. That means the tires are ready to use when they arrive!
What can you expect from a heat cycled tire vs. a normal tire? I am speaking mainly in terms of wear and performance. Can the heat cycled tires still be driven on the street?
Thanks
P.S. - Couldn't find anything with search, any suggestions?
[Modified by onyx00, 9:20 PM 1/23/2002]
[Modified by onyx00, 9:26 PM 1/23/2002]
Thanks
I used my A032R's that I heat cycled myself on and off the track. Thet lasted a LOOOOOOONG time. about ~8 months on the street, 3 full days on track... They are still up in the attic as backup spares. they are slicks now, but still no cords...
granracing
27
Jun 12, 2005 08:52 PM
nsxtasy
Jan 24, 2004 08:12 AM
nsxtcjr
Apr 23, 2002 09:15 AM
