93 civic gauge cluster won't light up(tail light works)???
i have a bone stock 93 civic ex automatic.about a week ago,i turned the light on at nite and the cluster didn't light up.i said,"Oh,i'll just change the fuse",but when i check the fuse,it was fine.all the tail light and everything works fine.if it's not a fuse then what can it be?at nite when the car is on and the lights are off,the automatic gear(the letter P,R,N,D,1,2) light up when you change gears but when you turn the head lights on,the automatic gear on the cluster goes out.what can i check?
i have this same problem.
to the left of your steering wheel there should be **** that adjusts how bright your dash lights are, that switch is probably bad
eg1Malik
Sep 3, 2015 01:48 AM
alispoon
13
Feb 27, 2006 09:09 AM
