RSX EP3 rear disc brake upgrade
Old Mar 15, 2005 | 08:05 PM
jade butterfly's Avatar
Default RSX EP3 rear disc brake upgrade for eg
my FIRST technical post... courtesy of my bf
rear disc brake upgrade for a 94 eg hatch.. enjoy
finally realized a good upgrade was needed when the damn car rolled backwards down a hill
it's pretty much a direct bolt on, only thing is that the calipers must be switched left and right becuase the RSX's brake cable is on the bottom instead of the top. and u'll need to bleed the brake when the caliper is off the car and flipped over since the bleeder screw ends up on the bottom.
here's another good write up:
https://honda-tech.com/zerothread?id=1110005
details, per requests :
Parts: calipers, brackets, EP3 4x100 rotors, and pads.
Prices: calipers (brand new) $120 a pop+ core charge, rotors $60 each, pads $20 for set of PBRs
Difficulty: on a range of 1-10, 10 being the hardest, it's a 4. it's pretty much bolt back on what u took off. just a little tricky bleeding with the calipers off the car.
Modified by jade butterfly at 10:01 PM 3/15/2005
Modified by jade butterfly at 11:38 PM 3/15/2005
Old Mar 15, 2005 | 08:31 PM
eK9aT10pSi's Avatar
Default Re: RSX EP3 rear disc brake upgrade (jade butterfly)
got a writeup of the parts needed/used , prices? comments about install, easyness/hardness ?
Old Mar 15, 2005 | 08:58 PM
BauleyCivic's Avatar
Risky Business
Default Re: RSX EP3 rear disc brake upgrade (eK9aT10pSi)
Good work!
Old Mar 15, 2005 | 09:36 PM
b1ackc1v1c's Avatar
nice
Old Mar 15, 2005 | 09:41 PM
bananaek's Avatar
Default Re: RSX EP3 rear disc brake upgrade (b1ackc1v1c)
dude t/y soo much
Old Mar 15, 2005 | 09:46 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: RSX EP3 rear disc brake upgrade (bananaek)
I think this is a first!
Old Mar 15, 2005 | 10:13 PM
E dwinbon G's Avatar
Default Re: RSX EP3 rear disc brake upgrade (litterbox)
https://honda-tech.com/zerothread?id=1090780 <--------- on an EK
Old Mar 15, 2005 | 10:35 PM
Default Re: RSX EP3 rear disc brake upgrade (E dwinbon G)
also, there are redrilled Prelude VTEC rotors and calipers on front for a full ITR spec brake setup, and SCREW 5 lugs.
Old Mar 15, 2005 | 11:55 PM
Airbag Club's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jade butterfly &raquo;</TD></TR><TR><TD CLASS="quote">also, there are redrilled Prelude VTEC rotors and calipers on front for a full ITR spec brake setup, and SCREW 5 lugs.</TD></TR></TABLE>
yep, that's the way to go. i was about to ask about your front setup. i have the same rear setup on my car right now, with stock 99 SI front's. if i slam on the brakes, the rear's will lock before the front's. this will be solved this weekend..
where did you buy your calipers from? you could have just pulled them off a car at the junk yard in hayward. that is where i bought mine from, $100 for the pair!
Mt3c
May 15, 2012 06:41 PM
jarel
Jul 23, 2008 08:20 PM
mickey513
Oct 2, 2003 04:35 AM
