JUN or Rocket Motorsport Cams
Old Mar 15, 2005 | 07:31 PM
BryanEk's Avatar
Default JUN or Rocket Motorsport Cams
On my B18c1 I want +200whp. I have Type R Pistons, Eagle Rods, Omni Power Valvetrain, Blow Manifold, Type R 4-1 and Type R TB. I was wondering what cams will give me the most power for $$ and also have the least aggressive idol (cant spell). What do you guys think?
Old Mar 15, 2005 | 07:38 PM
BryanEk's Avatar
Default Re: JUN or Rocket Motorsport Cams (BryanEk)
Also if JUN III's were used do you have to use JUN valvetrain? Would Omni Power work?
Old Mar 15, 2005 | 07:48 PM
UncleD's Avatar
Oh boy, where to start........
First off, people throw around the 200 whp as a benchmark, a goal that is "easily" reached. For one, your header will not get you that hp with those mods, the one thing you do have going for you is compression. Are you running usdm itr, jdm itr, or pct pistons? The Rm M22 vs. the jun 3 is a mystery....I personally went with the M22's. They are bigger than a Jun 3, but they may not idle as well as the Jun 3. The omni springs have light spring preasure, so I would determine how high you want to rev and make your decision from there. Another option you might think about is the Skunk 2 Pro 1's. Bottom line, the M22's WON'T let you down
Old Mar 15, 2005 | 08:23 PM
Rocket's Avatar
Default Re: JUN or Rocket Motorsport Cams (clean rice)
M22's idle really well when you run the chip I provide. You can ask GeezerCoupe or carcala. Carcala just beat a Sub STI with his GSR/M22 Powered Integra, too . Most peeps also get really good gas mileage >30mpg.
I can also provide custom maps for JUN's as well.
We cam doctored several cams JUNIII's and another very similiar cam and the ramps were slower than the M22's. Although the ramps are aggressive the profile is still very smooth and has almost no valvetrain noise on springs with about 65lbs on the seat. I was shocked at how silent the cams were with softer springs.
Old Mar 16, 2005 | 11:00 AM
BryanEk's Avatar
Default Re: JUN or Rocket Motorsport Cams (Rocket)
What header would you guys suggest? and I dont want to spend 1200 either
Old Mar 16, 2005 | 11:08 AM
Db1_77's Avatar
AN-R makes a very nice header that fits your price range, but it is prone to cracking.
I would recommend the header from Edelbrock (yes, bring on the flames).
Old Mar 16, 2005 | 12:40 PM
jdmcx's Avatar
Default Re: (hatch77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch77 &raquo;</TD></TR><TR><TD CLASS="quote"> I would recommend the header from Edelbrock (yes, bring on the flames).</TD></TR></TABLE>
don't you have to modify the collector to make 200???
Old Mar 16, 2005 | 05:38 PM
BryanEk's Avatar
Default Re: (jdmcx)
With the valve train I want to rev no more than 9500, so would omni power be sufficiant? Also where can I get an AN-R header cause I have searched yahoo like crazy and cant find one...
Old Mar 16, 2005 | 06:02 PM
UncleD's Avatar
Default Re: (BryanEk)
http://an-r.com/
Anr solved there "cracking" problem a LONG time ago......thats old news........
Omni's with M22's MIGHT be ok, Omni's with Jun 3's would work fine as they are smaller than the M22's..
Old Mar 16, 2005 | 06:19 PM
BryanEk's Avatar
Default Re: (clean rice)
Can I still run a/c with the an-r? And what is the difference between the merge and street collector? Also I'm assuming that the merge collector is for race only?
Old Mar 16, 2005 | 06:30 PM
BryanEk's Avatar
I mean what do I need to be able to run a/c?
Old Mar 16, 2005 | 07:08 PM
UncleD's Avatar
If you want to run ac then I would personally buy the Toda. It mkaes great power in almost any motor, and will clear all ac/radiator and give excellent ground clearence.
Old Mar 16, 2005 | 07:17 PM
BryanEk's Avatar
Yea but its $1000. Is the smsp close in performance? Also are those like special order only or something? Cant find them anywhere... online I mean.
Old Mar 16, 2005 | 07:23 PM
soLSvtec12kcraze's Avatar
i think weapon-r's will fit with a/c....they put out nice numbers for a $500 piece....but have also heard horror stories of them cracking as well....
smsp headers rock. heres a dyno vs. a PORTED ITR header with JUN 2 cams...it's on a mild-2liter set up, but just a general idea of how much more air passes through it.
Old Mar 16, 2005 | 07:46 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanEk &raquo;</TD></TR><TR><TD CLASS="quote">Yea but its $1000.</TD></TR></TABLE>
If you're complaining about a Toda costing 1k, then how do you think you're gonna do an sms? Also, you don't necesarily have to buy a header new, you can find used ones quite often...
Old Mar 16, 2005 | 08:00 PM
BryanEk's Avatar
Is the toda header carb legal? The site says off road use only...
Old Mar 16, 2005 | 08:09 PM
get your ride inspected before you buy it...
Old Mar 16, 2005 | 08:24 PM
SLOW EF8's Avatar
Default Re: (soLSvtec12kcraze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">If you want to run ac then I would personally buy the Toda. It mkaes great power in almost any motor, and will clear all ac/radiator and give excellent ground clearence.</TD></TR></TABLE>
TODA
Old Mar 16, 2005 | 08:35 PM
ChaseIntegra's Avatar
Default Re: (SLOW EF8)
I think Hookups headers are pretty affordable and seem to fit with A/C. Not sure, you might wanna IM HOOKUPS
Old Mar 16, 2005 | 09:14 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanEk &raquo;</TD></TR><TR><TD CLASS="quote">Is the toda header carb legal? The site says off road use only...</TD></TR></TABLE>
LOL answered your own question
Old Mar 16, 2005 | 09:19 PM
rodimus's Avatar
Default Re: (EVOL)
smsp has a 1 piece header with improvements over the old design out. i believe he said they'll cost around 600ish?
Old Mar 16, 2005 | 10:39 PM
supertran25's Avatar
Default Re: (EVOL)
no a/c with the an-r nice header
Old Mar 16, 2005 | 11:08 PM
wolve's Avatar
rocket,
maybe it's nice if you gave some detailed spec on your cams.
the duration on your site, is that advertised duration? when and when the answer is yes how much duration would they provide with the right amount of V/C???
the lift, is it cam lift or valve lift, and if it is cam lift what would be the valve lift with the recommended v/c???
how much duration/lift does the primary and secundairy lobe have??
i'd like to know this for the
M22 /284 /12.1 /284 /12.1
M24E /303 /12.7 /303 /12.7
M24X /298 /12.7 /305 /12.1
M25 /310 /12.1 /310 /12.1
M25E /316 /13.25 /216? /13.25
Old Mar 17, 2005 | 05:41 AM
wolve's Avatar
Default Re: JUN or Rocket Motorsport Cams (wolve)
rocket??
Old Mar 17, 2005 | 07:46 AM
wolve's Avatar
come on, tell us
