Power steering on my 2000 accord v6 is making a grinding sound.
Old Mar 15, 2005 | 07:14 PM
meggman's Avatar
Default Power steering on my 2000 accord v6 is making a grinding sound.
so the Power steering on my 2000 accord v6 is making a grinding sound and it gets a lot worse when i turn the wheel. also the fluid is spinning around inside of the tank when the motor is running. what could it be?
Old Mar 15, 2005 | 11:52 PM
iand415's Avatar
Default Re: Power steering on my 2000 accord v6 is making a grinding sound. (meggman)
power steering pump possibly? take it to the dealer
Old Mar 16, 2005 | 12:58 AM
philadd's Avatar
Default Re: Power steering on my 2000 accord v6 is making a grinding sound. (iand415)
fluid spinning around is normal.
have someone turn the wheel while you listen for the sound. if it's coming from the pump, well, its your pump...
Old Mar 16, 2005 | 06:54 AM
jweller's Avatar
Default Re: Power steering on my 2000 accord v6 is making a grinding sound. (philadd)
it's pretty easy to loosen the pump up and slip the belt off. if you still hear the the noise when the belt is off, you know it's not the pump.
the fluid bubbleing in the resivoir is normal
radDave
Transmission & Drivetrain
May 3, 2017 06:32 AM
Brett Curtis
Jun 13, 2016 03:29 PM
woainot
Dec 5, 2011 10:47 PM
Montie
Oct 12, 2005 07:39 PM
