Valve Cover Paint Question Quick
Old Mar 15, 2005 | 07:13 PM
luderollin's Avatar
Default Valve Cover Paint Question Quick
So correct me when im wrong and fill in blanks
1) Sand down valve cover with _______
2) Prime the sanded down valve cover with ____
3) Paint the valve cover with _____ (blue hopefully) (wrinkle paint i think)
for step one, i use aircraft paint remover to get the stock black stuff off my oem valve cover? them sand down with something?
also do i have to cover up holes so it doesnt drip down at all???
Old Mar 15, 2005 | 07:16 PM
Built to Spill's Avatar
el diablo
Default Re: Valve Cover Paint Question Quick (luderollin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luderollin &raquo;</TD></TR><TR><TD CLASS="quote">So correct me when im wrong and fill in blanks
3) Paint the valve cover with _____ (blue hopefully) (wrinkle paint i think)</TD></TR></TABLE>
1)sandpaper
2)primer
3)paint
Just use aircraft stripper to take the original paint off. Then use a light sandpaper grit to rough up the surface without scratching it too deep. Then primer and paint using high-temp paint.
edit: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also do i have to cover up holes so it doesnt drip down at all???</TD></TR></TABLE>
I dont understand this question...you are planning on doing this with the valve cover off right?
Old Mar 15, 2005 | 07:25 PM
_Spugen_'s Avatar
Theres several DIY in the civic section...
Old Mar 15, 2005 | 07:36 PM
luderollin's Avatar
Default Re: Valve Cover Paint Question Quick (Built to Spill)
yea the cover is off just didnt know if it mattered when i put it back on shouldnt but i didnt know
felixjr18
Paint and Body
Apr 29, 2009 11:07 AM
bayareacivic
Oct 30, 2008 08:35 PM
NACvicSi
Jul 26, 2007 03:55 PM
Dancing is Forbidden
11
Jun 24, 2003 05:43 AM
ih8danoles
Oct 27, 2002 01:22 PM
