Re-Bedding Pads?
Old Mar 15, 2005 | 06:09 PM
Flux's Avatar
Default Re-Bedding Pads?
I just installed my Cobalt Spec VR pads in preparation for my first track time of the new year on Thursday (track is only about 20 minutes away). These pads have not been used since my last track day in the fall, but my car has seen very few miles since then. Do I need to re-bed the pads (using the new pad procedure) or will the drive to the track be enough?
Old Mar 15, 2005 | 06:39 PM
Willard's Avatar
Default Re: Re-Bedding Pads? (Flux)
the drive to the track should be enough...
i would swap them on a few days before and drive the car to work to help smooth the surface up.
since they have seen track use before they are ready to rock and roll.
Chris F's Avatar
I've swapped rotors at the track and skipped the bed-in procedure, even though the rotors were last run on a different compound. They decided to warp or at least not distribute the pad material evenly, but they lasted through the day no problems. YMMV.
You may want to bed them again to get an even amount of the new pad material spread across the rotor.
-Chris
Old Mar 15, 2005 | 06:45 PM
Willard's Avatar
Default Re: Re-Bedding Pads? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">You may want to bed them again to get an even amount of the new pad material spread across the rotor. </TD></TR></TABLE>
this is a good plan..
I was thinking that he might have a set of rotors for track use (matched with a set of track pads).
If you are just swapping pads.. there will be some pulsations until the current pad material has worn off and the new pad material has transfered over.
Old Mar 15, 2005 | 06:55 PM
Chris F's Avatar
Default Re: Re-Bedding Pads? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
Better plan: Run Spec VR's on the street, stop worrying about rebedding pads
Old Mar 15, 2005 | 07:04 PM
Willard's Avatar
I have... for a few weeks at a time. (the ITR is not the daily driver).
the surfaces clean up quite nicely and "I" think that it helps pro-long pad life.
Old Mar 15, 2005 | 07:14 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">I have... for a few weeks at a time. (the ITR is not the daily driver). </TD></TR></TABLE>
I've been running them for a few months, DD. I swear I will never buy another brand of brake pad for this car.
-Chris
Old Mar 15, 2005 | 07:21 PM
Flux's Avatar
Thanks guys - I'll ssut bed them in again.. can't hurt for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">I swear I will never buy another brand of brake pad for this car.
Ain't that the truth...
Old Mar 15, 2005 | 08:17 PM
BlueR's Avatar
-Chris</TD></TR></TABLE>
its just that you'd wasting a $150 pad on the street when a set of $50 pads will do...
don't get me wrong, i dd my spec VRs
never need to switch them out or rebed
Old Mar 16, 2005 | 02:28 AM
Chris93Si's Avatar
I've been running them for a few months, DD.</TD></TR></TABLE>
I'm joining the VR DD club this weekend
Flux take plenty of pixors w/ the new camera
Old Mar 16, 2005 | 04:55 AM
1GreyTeg's Avatar
the surfaces clean up quite nicely and "I" think that it helps pro-long pad life.</TD></TR></TABLE>
In the VR's case this might be true, although I never really noticed anything for street driving besides a hint less braking ability for initial cold stops. Just gotta be more careful.
The Hawk Blues on the other hand had a bit better initial torque for cold street braking but absolutely tore up my rotors.
Best case scenario would be to at the very least run GT sports on the street and Swap in VR's at the track. But who am I to talk, I haven't run anything close to street pads for the last 4 years. It's hard to go back when the braking is just so awesome.
Old Mar 16, 2005 | 05:50 AM
Flux's Avatar
Default Re: Re-Bedding Pads? (Chris93Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Flux take plenty of pixors w/ the new camera </TD></TR></TABLE>
You know it...
Rekorb9
Honda Civic Type-R (2017 - Current)
12
Oct 9, 2019 07:02 AM
Flux
Jun 8, 2004 06:38 PM
RATEDR
Mar 1, 2002 10:37 AM
MaddMatt
Mar 1, 2002 02:48 AM
