Suspension & Brakes Theory, alignment, spring rates....
integra rear lca question
Old Mar 15, 2005 | 05:29 PM
93civicsedan's Avatar
Default integra rear lca question
First off I tried searching but couldnt find any pics. I want to know if integra rear lca's are supposed to have a curve in them. I got these lca from a 97 GS when I bought my rear disc conversion. I checked a friends 97 Gsr arms and I didnt see much of a curve. I know my stock civic lca dont have the curve. Will these bolt up to my 93 civic? I need them for the sway bar holes but I am not sure if the curve in these is normal. Thanks alot.
Old Mar 15, 2005 | 05:43 PM
wreckedagain's Avatar
mine dont have that,
Old Mar 15, 2005 | 05:44 PM
Default Re: (wreckedagain)
not to be a dick but where were those things from the ocean..
Old Mar 16, 2005 | 05:28 AM
no they are not from the ocean, why do you say that cause of the tiles? anyone know if they are supposed to be curved?
Old Mar 16, 2005 | 03:24 PM
integral94's Avatar
Default Re: (93civicsedan)
my rlca's are curved a bit... when you look at the rear of the car they go from _ to a sort of incline to the subframe... i dont know about the curve that you are showing with those pics... i would go to a dealership and ask to see the ones they have in stock. that would tell you whether or not those are bent to hell or not.
Old Mar 16, 2005 | 03:48 PM
Tyson's Avatar
Default Re: integra rear lca question (93civicsedan)
thats normal. i can say CRX/civics all 89+ do.
Old Mar 16, 2005 | 04:33 PM
dwnthehatch's Avatar
It's normal.
Old Mar 16, 2005 | 10:03 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: integra rear lca question (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">It's normal.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">thats normal. i can say CRX/civics all 89+ do.</TD></TR></TABLE>
Old Mar 17, 2005 | 11:03 AM
Default Re: integra rear lca question (94eg!)
thanks for all the replies.
Old Mar 17, 2005 | 01:07 PM
nonsense's Avatar
Default Re: integra rear lca question (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">thats normal. i can say CRX/civics all 89+ do. </TD></TR></TABLE>
Maybe 89-95, but my 99 rear LCAs don't look like that at all.
Old Mar 17, 2005 | 02:02 PM
Tyson's Avatar
Default Re: integra rear lca question (nonsense)
youre right, after 95 they went to an ugly stamped steel piece. i actually only meant 89-91, even tho 92-95 civics are the same too.
Old Mar 18, 2005 | 08:03 AM
mike-y's Avatar
My 95 GSR rear LCAs were curved like that.
My 92 civic had straight LCA's, but also no rear swaybar mount holes.
My 89 civic had curved LCAs.
other then the bend, the length and mounting points on all were identacle.
Old May 13, 2005 | 05:05 PM
OEMwh0r3's Avatar
Default Re: integra rear lca question (mike-y)
line the LCA's next to each other.. if all the holes don't line up correctly then one of them is bent.
Old May 13, 2005 | 05:08 PM
.RJ's Avatar
.RJ
Default Re: integra rear lca question (OEMwh0r3)
I have seen both straight and bent on civic/integras - they are interchangeable (all the bolt holes line up in the same place on both arms)
I can see why its done that way.... if you hit a curb, the LCA will fold up, rather than transfer the impact to the subframe, which is a bit harder to replace.
mxkilla450
Mar 25, 2009 07:52 PM
88 EF Hatch
Mar 3, 2009 08:47 AM
tortis
Suspension & Brakes
Nov 3, 2007 04:10 PM
93civicsedan
Mar 18, 2005 06:44 AM
