CTR pistons in a B18C5
Ive already searched and some people say its ok and some dont. Anyone actually have this done on theyre daily driver? Stock everything else.
thanks for any info in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">would u even see a difference since its an itr?</TD></TR></TABLE>
...the CTR pistons would raise the compression like a ****.
Anyway. I wouldn't do it on my daily driver...but I'm not talking for experience. So.
i wouldnt do it if it didnt do anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pacifico »</TD></TR><TR><TD CLASS="quote">
thats cool. some people are not the same, though.
</TD></TR></TABLE>thats cool. some people are not the same, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpoweredeg »</TD></TR><TR><TD CLASS="quote">whats the difrence between both? can u do it on a gsr?</TD></TR></TABLE>
ctr is higher compression.
back on topic.....anyone do this to their daily driver b18c5?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bananaek »</TD></TR><TR><TD CLASS="quote">ctr pistions huummmm 12.3 - 12.5 comperssion
https://honda-tech.com/zerothread?id=717928
its that easy
</TD></TR></TABLE>https://honda-tech.com/zerothread?id=717928
its that easy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpoweredeg »</TD></TR><TR><TD CLASS="quote">can u replace the pistons and leave the rest normal? would it be safe?</TD></TR></TABLE>
its a rebuild.....new bearings, rings & lower gasket kit w/ headgasket....... 12+ compression = race full or 100 + octane...... w/ ctrs check piston to valve clearance
Try 12.9:1.
</TD></TR></TABLE>Try 12.9:1.
personally i wouldnt because it could blow it but u might be able to if u set back the timing which u will lose hp and tune it for that octane. for a cr of almost 13 u should be using 100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pacifico »</TD></TR><TR><TD CLASS="quote">i couldnt run 93? Thats all we have here</TD></TR></TABLE>
On compression that high? You MIGHT be able to tune it to run on 93, but like has already been said, you will be pulling timing like mad to compensate from it. This is going to get rid of a good amount of the gains from putting those pistons in. CTR pistons in general are not a good selection imo. Flame propagation is comprimised, they are heavy, and the domes are just too large for most applications.
if your looking for that compression it will prob be easier to get some aftermarket pistons that way you will have deep valve reliefs if you choose to get big cams. bigger cams will be a def plus. !!
it will run fine as long as you got the fuel there...as for 93 octane you should be fine...my homie runs um daily on his itr swap...no problems
as for compression it would only be around 12.1-12.3 at most...as long as your using stock head gasket and the head is not milled or anything
using type-r block and head, and stock head gasket
