Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic
Old Mar 15, 2005 | 04:34 PM
DarkBB4's Avatar
Default Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic
Im going to pick up a jdm h22a type s motor..with LSD tranny. How can i make sure that everythign is Type S that is supposed to be..
It has teh type s intake.
What color valve cover should it have?
What is the tranny code?
How can i prove it has type s cams?
Anything on the block? it should read h22a (correct?)
Old Mar 15, 2005 | 04:54 PM
sup gurl's Avatar
block should read h22a, valve cover could be red or black I dont think anything else.
Thats all I know of?
edit: oh and sell me your intake
Old Mar 15, 2005 | 05:09 PM
bad-monkey's Avatar
Default Re: Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">Im going to pick up a jdm h22a type s motor..with LSD tranny. How can i make sure that everythign is Type S that is supposed to be..
Anything on the block? it should read h22a (correct?)</TD></TR></TABLE>
for starters:
if it's got an LSD tranny then it's not a "Type S" motor. the BB6 type S came with ATTS.
but, it could be a 4th gen JDM H22 from an SiR-G, which came with the LSD tranny.
Old Mar 15, 2005 | 05:22 PM
OEM_ASSASSIN's Avatar
Default Re: Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic (bad-monkey)
^I thought type s was available with either.
Old Mar 15, 2005 | 05:23 PM
bad-monkey's Avatar
Default Re: Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic (OEM_ASSASSIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OEM_ASSASSIN &raquo;</TD></TR><TR><TD CLASS="quote">^I thought type s was available with either.</TD></TR></TABLE>
nope. it's my understanding that all 5th gen type S's had ATTS.
Old Mar 15, 2005 | 05:26 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">
nope. it's my understanding that all 5th gen type S's had ATTS.</TD></TR></TABLE>
That's what I thought too. The Type S is the same as our Type SH....with more aggressive cams and higher comp pistons.
Old Mar 15, 2005 | 05:39 PM
Default Re: Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic (AndyD)
SIR SPEC-S is what I was thinking of. I looked it up in the FAQ
Old Mar 15, 2005 | 05:54 PM
sharkcohen's Avatar
If the transmission code is M2B4, then you want to give it to me.
Old Mar 15, 2005 | 05:57 PM
DarkBB4's Avatar
Default Re: Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic (sharkcohen)
well its obd2 and he says its "type s" comes with type s intake.. maybe the trannys from a jdm h22a with lsd i donna
antyhing else i can do? isn't hte valve cover supposdtto be red? or blue?
Old Mar 15, 2005 | 06:02 PM
AndyD's Avatar
Aren't the Type S blocks different from the non Type S blocks?? The trans are not interchangeable. It requires modification to make a non Type S trans fit a Type S block, I believe.
Old Mar 15, 2005 | 06:40 PM
sharkcohen's Avatar
It takes a bit of fabrication, yes.
Old Mar 15, 2005 | 06:48 PM
DarkBB4's Avatar
anything
he said the compresion was almost 12:1
are the cams marked at all? for type s?
Old Mar 15, 2005 | 07:00 PM
sharkcohen's Avatar
First the guy says it's a Type S and has LSD, now he's saying the compression is 12:1. Either he's an idiot, or he is hoping you are.
Old Mar 15, 2005 | 07:06 PM
4bidden's Avatar
Measure the throttle body. Nobody who is trying to scam off a fake Type-S will even think to correct that issue.
Old Mar 15, 2005 | 09:00 PM
A Blue Lude's Avatar
Default Re: Going to pick up jdm h22a TYPE S motor.. how can i know everything is authentic (4bidden)
SiR S-spec engines seems to be frequently reffered to as Type-S. It seems pretty plausable that you could have a "Type-S" engine w/LSD. *shrug*
Old Mar 15, 2005 | 09:45 PM
bad-monkey's Avatar
sounds shady, hope you aren't paying too much money for it.
Old Mar 16, 2005 | 03:07 AM
DarkBB4's Avatar
Default Re: (bad-monkey)
is 700 bucks with lsd tranny, block, ecu, intake, new vtec soleniod and alternator, no pistons , full type s head
a good deal?
Old Mar 16, 2005 | 04:21 AM
Monkey Fing a Coconut's Avatar
Default Re: (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">is 700 bucks with lsd tranny, block, ecu, intake, new vtec soleniod and alternator, no pistons , full type s head
a good deal?</TD></TR></TABLE>
the m2b4 tranny alone is worth at least $700, so yes, but if u factor in labor to put in the pistons and crank and head(unless u are doing that yourself) then it may come out to more than buying a complete swap
Old Mar 16, 2005 | 08:07 AM
DarkBB4's Avatar
Default Re: (twistedbydezign)
well i am parting it out, so im just selling everything
I think im gonna hold onto the head and the type s intake for the jdm bling obviously...
the head will fit on my h22a1 fine right?
Old Mar 16, 2005 | 08:11 AM
sharkcohen's Avatar
You're parting it out? Dude, seriously, if it turns out to be an M2B4 tranny, I'd be interested in buying it.
Yes, the head will work fine.
Old Mar 16, 2005 | 11:25 AM
DarkBB4's Avatar
Default Re: (sharkcohen)
ok, i fanyone could give me a hand with pricing things (tother than the tranny) such as Head, Block, new alternator and vtec soleniod and etc... let me now
Old Mar 16, 2005 | 12:09 PM
sup gurl's Avatar
If you are parting it out hook me up with that Type S intake !
Old Mar 16, 2005 | 12:17 PM
98TypeSH's Avatar
im willing to bet a good amount of money its not an M2B4 trans, and its not a type S block. Atleast read the motor code. If the trans is off , look at the diff. If you can see straight thru it its LSD if not then it isnt.
And its my understanding the M2B4 was off a euro R not a type S. Something just dont seem right. research more and take pictures of all the crap before you buy it and see if you can identify some of it.
Old Mar 16, 2005 | 12:20 PM
DarkBB4's Avatar
Default Re: (98TypeSH)
well the lsd tranny has 10k on it and the motor has around 11k he said
Why would he sell me the type s intake with it then?
What is the motor code suppsoed to be.. just h22a?
Old Mar 16, 2005 | 12:24 PM
98TypeSH's Avatar
yes but it could very well just be a plain JDM swap. ask him where he got it from and if its a local place ask for a contact so you can call and verify. Just use your brain here, do you want to be fucked for 700 bucks? i know i wouldent.
I also told you how to tell if its REALLY lsd. i smell a big pile of bullshit.
