OIL FILTER TIP use RSX OIL FILTERS
Old Mar 15, 2005 | 03:34 PM
slammedc2x's Avatar
Default OIL FILTER TIP use RSX OIL FILTERS
I bought a b20 civic and da homie mention to use RSX oil filters, cuz it holds more oil. Im not sure if it will help much. just a tip. the rsx oil filters are a bit longer than normal honda filters. I just assume it's better.
Old Mar 15, 2005 | 03:36 PM
gsrious's Avatar
Default Re: OIL FILTER TIP use RSX OIL FILTERS (slammedc2x)
does it screw on to the b18c motors...perfectly???
Old Mar 15, 2005 | 03:39 PM
JamaicanDM's Avatar
Default Re: OIL FILTER TIP use RSX OIL FILTERS (red dc2)
yes it does screws on there perfectly there are a couple of threads about this a while search in the acrhives.
Old Mar 15, 2005 | 03:40 PM
Rtistik.'s Avatar
Default Re: OIL FILTER TIP use RSX OIL FILTERS (JamaicanDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamaicanDM &raquo;</TD></TR><TR><TD CLASS="quote">yes it does screws on there perfectly there are a couple of threads about this a while search in the acrhives.</TD></TR></TABLE>
goin to the search button
Old Mar 15, 2005 | 05:26 PM
Rory Breaker's Avatar
Default Re: OIL FILTER TIP use RSX OIL FILTERS (rtistik)
It doesnt hold more oil, its actually smaller. It raises oil pressure a few PSI.
No thanks. Ill stick with what Honda intended when they made my motor way back when.
Old Mar 15, 2005 | 05:31 PM
LT6916's Avatar
Durka durka
Default Re: OIL FILTER TIP use RSX OIL FILTERS (Rory Breaker)
same. i dont think i want to "try" something that is part of a vital system. if you want get the Mugen filters or put a hose-clamp around your current filter.
Old Mar 15, 2005 | 07:11 PM
s2kdre's Avatar
Default Re: OIL FILTER TIP use RSX OIL FILTERS (LT6916)
we been using those filters for 4 years now.
Old Mar 15, 2005 | 07:15 PM
eK9aT10pSi's Avatar
Default Re: OIL FILTER TIP use RSX OIL FILTERS (jdmhonda)
isnt the rsx filters longer but narrow ? the s2k was the biggest filter til they made it the same size as other hondas
Old Mar 16, 2005 | 07:16 PM
gutted's Avatar
Default Re: OIL FILTER TIP use RSX OIL FILTERS (eK9aT10pSi)
umm they are all the same oil filters integra, crv, civic, accord, tl, cl, mdx, rsx & tsx. only ones that are different is the old rl, nsx, s2000 & legend. honda jus switched over to the smaller sized filter but i know of some places who still have some left over "bigger" style oil filters.
Old Mar 16, 2005 | 07:39 PM
TeaAddict's Avatar
Default Re: OIL FILTER TIP use RSX OIL FILTERS (gutted)
cost/benefit analysis says
thanks though.
JDMBOY1904
Jun 15, 2009 12:01 PM
pmey
Dec 19, 2008 01:34 PM
KF_S2000
Aug 13, 2003 12:07 PM
Tweakmeister
Feb 23, 2003 01:54 PM
infamousALLMTR
Jun 3, 2002 07:35 PM
