Car feels wobbly/unstable/bouncy even driving on flat road.
Old Mar 15, 2005 | 03:23 PM
rasinhell's Avatar
Default Car feels wobbly/unstable/bouncy even driving on flat road.
Hey guys. My car wobbles almost or feels bouncy and unstable. LOL I know, confusing huh. I can't really explain it but it just doesn't feel safe. I'm on flat roads when i drive it, just up and down the block and it still feels bouncy.
Is this what bad bearings feels like?
Old Mar 15, 2005 | 04:51 PM
eK9aT10pSi's Avatar
Default Re: Car feels wobbly/unstable/bouncy even driving on flat road. (The-Beast)
a bad wheel bearing makes an annoying noise and shakes the car. the bouncing sounds like a blown strut issue.
Old Mar 15, 2005 | 04:55 PM
r6samson's Avatar
Ball joints is a possibility.
JP
Old Mar 16, 2005 | 06:29 PM
rasinhell's Avatar
Default Re: (r6samson)
will it really bounce though, even on flat road?
Old Mar 16, 2005 | 06:33 PM
lumpbuzcut's Avatar
Default Re: (The-Beast)
the slightest bump will make it ride like poop if you have a blown shock. feels super un-safe while doing 65 on a crappy highway.
Old Mar 16, 2005 | 06:36 PM
EVIL Hx Coupe's Avatar
Default Re: (lumpbuzcut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lumpbuzcut &raquo;</TD></TR><TR><TD CLASS="quote">the slightest bump will make it ride like poop if you have a blown shock. feels super un-safe while doing 65 on a crappy highway.</TD></TR></TABLE>
Whats your suspension setup?? I'm almost positive you're riding on bumpstops.
Old Mar 16, 2005 | 06:38 PM
''s Avatar
possibly a messed up tie rod as well.
Old Mar 16, 2005 | 06:59 PM
dohcdelsol's Avatar
Default Re: (l337hxr)
wheels not in balance?
I know it would feel like a wobble but at a higher speed if that was the case.
Whats your suspension set up?
Old Mar 16, 2005 | 08:11 PM
rasinhell's Avatar
Default Re: (dohcdelsol)
Well the shocks are Billstien i dont know much more then that and the coilovers are ground control set like at 3.5in drop almost.
Here is the thing guys. A while back I was working on my car. I had swapped the motor in and then I went out the test drive it up and down the block. The car starts making a clicking noise and then the front left of the car drops. I was scared as ****, even though I was just in the neighborhood and there was no immediate danger like getting hit from behind, it was a crazy experience. I look under the car and the nut for the lower ball joint is off, and the ball joint came out of the LCA and the entire tire was butterflied like / and it fucked up the fender. It was real crazy. And then I fix everything, replace the ball joint because it was messed up. And I test drive it and it feels wobblish and **** like I described.
So I guess it could be a host of factors, the shocks fucked up, maybe the tie rod got stretched out or something when the tire popped out. I just dont know.
Luckily it's not a daily driver, just a project so it isn't something that needs to be fixed immediately. But for now I just want to isolate the problem so i dont go out spending money on things I didn't need.
Yea i know what u guys are thinking, I shoulda told u the first time i posted how this happened lol.
Old Mar 16, 2005 | 11:21 PM
rasinhell's Avatar
bump
Old Mar 17, 2005 | 04:33 AM
Do you have bumpstops in there??? When you lower your car you need to cut them in half, if not the car rests on them, or bounces off of them with minimal road imperfections... This causes crazy unestability and bouncing.
Old Mar 17, 2005 | 01:55 PM
rasinhell's Avatar
Default Re: (EVIL Hx Coupe)
hmm... well the thing is, the instability started after the incident where the balljoint nut came off and the wheel butterflied. It wasn't like that before it happened.
Old Mar 17, 2005 | 02:45 PM
Sijray21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">wheels not in balance? </TD></TR></TABLE>
That was my thought, when was the last time you had your wheels balanced?
Could also be blown shocks or a bad alignment, check those.
Wheel bearings will make a noise related to the speed at which you are traveling (ie: increasing noise, repeating more as you increase in speed)
chrisdavis6
Jun 4, 2008 06:43 AM
YoungKadafi
Suspension & Brakes
Apr 16, 2007 09:13 AM
e jay one
10
Mar 21, 2007 11:37 AM
1sikcoupe
Feb 27, 2007 06:57 PM
fe519
May 16, 2003 10:18 AM
