Has anyone ever done 86mm Bore ona B20 Block?
Old Mar 15, 2005 | 01:09 PM
Suprdave's Avatar
Default Has anyone ever done 86mm Bore ona B20 Block?
I was told I couldn't do 86mm ona B20 because of some bullshit reason.
It's an RS Machine Sleeved B20...I'm guessing Darton Dry Sleeves.
What makes a GSR\LS 86mm Boreable, and a B20 isn't. I can't see a big difference between 85mm and 86 on the structural integrity.
Old Mar 16, 2005 | 02:38 PM
Suprdave's Avatar
Default Re: Has anyone ever done 86mm Bore ona B20 Block? (Suprdave)
up...
Old Mar 16, 2005 | 03:06 PM
West Werks's Avatar
I have a 86mm b20 block. From my stand point its better to use a b20 block because the water jacket is a little larger in diameter than any other b-series. Just my $.02
Old Mar 16, 2005 | 05:43 PM
Suprdave's Avatar
Default Re: Has anyone ever done 86mm Bore ona B20 Block? (VenGeanceDrag)
As long as it CAN be bored to 86 without any problems...I don't give a **** about anything else...thanks for personal experience.
Old Mar 16, 2005 | 06:03 PM
Bradstard's Avatar
Yes, it can be done. RLZ has many 86mm B series motors that they have built. They were calling me a ***** for only going 85mm on my motor.
Old Mar 16, 2005 | 06:21 PM
Suprdave's Avatar
No No No...I KNOW you can do 86mm on most B Series blocks...I'm talking specifically of the B20 Block. I was told that the B20 could only be bored to 85mm. Obviously this doesn't make and sense...hah.
Old Mar 16, 2005 | 06:30 PM
justBLZE's Avatar
Chopper 2 Hopper
Wasn't it something about webbing cylinder walls?
Bump for an answer.
Old Mar 16, 2005 | 08:08 PM
sheepey's Avatar
a good friend of mine has a b20 86mm. runs just fine and great
Old Mar 16, 2005 | 09:11 PM
TRAN's Avatar
Default Re: (sheepey)
yes you can go 86mm on b20. its better to sleeve a b20 to 86mm cause it has a bigger OD on the factory sleeves. for more support. And what VenGeanceDrag said, i has more space for coolant
Old Mar 16, 2005 | 10:27 PM
Eviloliv3's Avatar
Default Re: (TRAN)
the cylinder walls are comprised of a different material. if its a sleeved motor you are talking about, which seems to be the case, then you can bore it out just fine since you are using the same material thats in all other sleeved motors.
now as to the comment about the water jackets..... put up some evidence. ive measured a LS and a B20 and they were the same.
Old Mar 16, 2005 | 11:02 PM
sheepey's Avatar
yea i was talkin about sleeved. he has ge
Old Mar 17, 2005 | 12:00 AM
wolve's Avatar
what about a 86 mm bore on a b16a, sleeved offcourse????
Old Mar 17, 2005 | 12:04 AM
sheepey's Avatar
Default Re: Has anyone ever done 86mm Bore ona B20 Block? (wolve)
yep, i have 85mm b16
Old Mar 17, 2005 | 12:59 AM
A train's Avatar
Default Re: Has anyone ever done 86mm Bore ona B20 Block? (sheepey)
ive been 86.5 on a b20 no probs dave and ill bore it to 87 next thats it though!
Old Mar 17, 2005 | 03:55 AM
Blind-Fashion's Avatar
what people where probably saying to you is that you can't go over 85mm on STOCK sleeves. you can go out to 87mm on most aftermarket sleeves. so your answer is YES on a B20 BLOCK SLEEVED you can go 86mm
Old Mar 17, 2005 | 04:50 AM
TurboJesse
Guest
Posts: n/a
Default Re: (Blind Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">what people where probably saying to you is that you can't go over 85mm on STOCK sleeves. you can go out to 87mm on most aftermarket sleeves. so your answer is YES on a B20 BLOCK SLEEVED you can go 86mm</TD></TR></TABLE>
no people are talking about sleeved blocks...
Sleeving a b20 block is different than a b18/b16, etc. Notice how it usually costs more.
Old Mar 17, 2005 | 08:25 AM
asubennett's Avatar
Default Re: (Mpir3)
Dave- I think this will help you a bit.
I have an RS machines sleeved block as you do. Through some research I figured out the sleeved they use are LA Sleeves. Rocket helped me find their web site.
Anyhow, I spoke with LA and they said you can actually take these sleeves out to 87mm if you so desire. I just had my block bored and torque plate honed to 86mm with some CP pistons from Rocket.
Everything checked out fine at the machine shop.
Only difference is this is an LS block.
Old Mar 17, 2005 | 10:42 AM
TRAN's Avatar
Default Re: (Eviloliv3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eviloliv3 &raquo;</TD></TR><TR><TD CLASS="quote">now as to the comment about the water jackets..... put up some evidence. ive measured a LS and a B20 and they were the same.</TD></TR></TABLE>
you might need to check again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Dave- I think this will help you a bit.
Only difference is this is an LS block. </TD></TR></TABLE>
it doesn't matter what or whos sleeves they are. just matter whats the OUTTER DIA. of the sleeve. to see how much room there is to go big on the bore size
Old Mar 17, 2005 | 11:10 AM
asubennett's Avatar
Default Re: (TRAN)
I didn't realaize the outer diameter was the only limiting factor. Some of GE's sleeves won't accept an 86mm bore and some do and I have not noticed a difference in their outer diameter. Maybe I am crazy.
Old Mar 17, 2005 | 12:14 PM
Suprdave's Avatar
Default Re: (asubennett)
**** It, I'm just going to do it...see what happens.
Old Mar 18, 2005 | 02:56 AM
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">no people are talking about sleeved blocks...
Sleeving a b20 block is different than a b18/b16, etc. Notice how it usually costs more.</TD></TR></TABLE>
Thank you know it all
The reason for the sleeving costing more on a b20 is because of the extra work that is involed in getting the "one piece" cylinder milled out.
Thank you come again :-*
Old Mar 19, 2005 | 11:00 AM
vtecmissle's Avatar
why not go 86.5 or 87 show us the possibilities.
Old Mar 19, 2005 | 11:35 AM
BigC-ivic's Avatar
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">**** It, I'm just going to do it...see what happens.</TD></TR></TABLE>
thats the spirit!
Old Mar 23, 2005 | 05:12 AM
StorminMatt's Avatar
Default Re: (vtecmissle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle &raquo;</TD></TR><TR><TD CLASS="quote">why not go 86.5 or 87 show us the possibilities.</TD></TR></TABLE>
Keep in mind that bore spacing on a B-series motor is 90mm. This means that with 87mm bores, there is only 3mm of material between adjacent cylinders. Also, since there is no such thing as aftermarket siamesed sleeves, the actual thickness of the sleeve narrows to 1.5mm between the cylinders with an 87mm bore!
andrearcher2003
Sep 27, 2011 04:15 PM
blackeg
Aug 9, 2008 03:06 PM
-KangaRod-
Jun 24, 2004 02:29 PM
