missing sound.. rained really bad yesterday ..
Old Mar 15, 2005 | 11:26 AM
pane93civhb's Avatar
Default missing sound.. rained really bad yesterday ..
I have a vented hood and im sure water can get into the intake if it rains really hard which it did. i parked my car and came out maybe an hour later while it sat.. i started it up.. when i rev it it has a horrible bog sound. i had to drive it home i did at like 30mph in 5gear about 5miles its been parked since yesterday, havent started it yet..
wondering what precautions would u take if this happend to u. ima try to start the car again when i go back home after work.
I was thinking maybe drain the oil and let it sit then refil it but im not sure what else.
Old Mar 15, 2005 | 11:32 AM
jlacoy82's Avatar
71.192.16.183
Default Re: missing sound.. rained really bad yesterday .. (pane93civhb)
Change your oil. Disconnect injector plugs, remove spark plugs and crank engine over a few times to clear out anything that might have been sitting in the intake mani/intake, then put it back together and give it a go?
Old Mar 15, 2005 | 11:50 AM
Default Re: missing sound.. rained really bad yesterday .. (jlacoy82)
that sounds good.. im going to try that that is alot of work though for sure... i should star tthe engine with no injectors or oil in it at all. are u sure that is safe.
Old Mar 15, 2005 | 11:55 AM
IHateJDM's Avatar
no injectors= no fuel. No fuel means the engine won't actually run. Turning the crank and cycling the motor will clean out the cylinders.
Old Mar 15, 2005 | 11:58 AM
jlacoy82's Avatar
71.192.16.183
Default Re: missing sound.. rained really bad yesterday .. (93delslo)
No, REFILL the oil before you try starting it. I think that goes without saying.
Change your oil/filter, refill it.
Remove the injector harness cover and simply unplug the clips from the injectors, its very simple. And removing the spark plugs takes all of 5 minutes.
Disassembly and reassembly shouldnt take you but an hour and a half at most.
Old Mar 15, 2005 | 01:36 PM
im going to try that when i get home if im not too lazy.. otherwise ill wait till my day off. is there a way to dry the cylinders were the spark plugs are..
Old Mar 15, 2005 | 01:38 PM
jlacoy82's Avatar
71.192.16.183
Yes..........by doing what I just typed out above.
91_e_f
Apr 6, 2011 11:32 PM
gosu08
Sep 9, 2007 12:23 PM
nappyroots827
Jul 31, 2006 08:29 AM
chubbz
Dec 18, 2005 09:43 AM
Hyb
Mar 23, 2005 07:04 PM
