Stainless steel Or Mild tubing for IC piping
Old Mar 15, 2005 | 08:32 AM
Fab-Works's Avatar
Default Which do you guys prefer :Stainless steel Or Mild tubing for IC piping
Sup guys I was wondering which do you guys prefer. Stainless or mild tubing for ic piping. Right now cant do aluminum i know that is the best. Thanks guys.
Old Mar 15, 2005 | 09:23 AM
dustin's Avatar
Default Re: Which do you guys prefer :Stainless steel Or Mild tubing for IC piping (anthonycn)
I vote mild steel. stainless is expensive.
Old Mar 15, 2005 | 09:28 AM
EJ1 wilcox's Avatar
Default Re: Which do you guys prefer :Stainless steel Or Mild tubing for IC piping (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">I vote mild steel. stainless is expensive.</TD></TR></TABLE>
Me too... it's cheaper to buy, and easier to work with...
Old Mar 15, 2005 | 09:37 AM
Fab-Works's Avatar
Default Re: Which do you guys prefer :Stainless steel Or Mild tubing for IC piping (EJ1 wilcox)
what if price isnt the issue. I get ss for pretty cheap. Im just alking bout **** performance wise? I am going to produce these and wondering which u guys prefer and the price for ss isnt that much more then mild . thanks alot guys
Old Mar 15, 2005 | 09:46 AM
beepy's Avatar
Aluminum. Its cheaper than both and makes the ideal pipe material (lightweight, high thermal conduction rate)
Old Mar 15, 2005 | 09:52 AM
dustin's Avatar
stainless is heavy too
Old Mar 16, 2005 | 08:40 AM
Fab-Works's Avatar
Thanks guys, Aluminum cost a bit more then stainless but you guys covinced me to go with alum. You guys will like
Old Mar 16, 2005 | 09:04 AM
Iceman05's Avatar
SS has more heat transfer, worse for ic pipes... alum is the way to go. cheaper, lighter, better performance....
Old Mar 16, 2005 | 09:12 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anthonycn &raquo;</TD></TR><TR><TD CLASS="quote">Aluminum cost a bit more </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iceman05 &raquo;</TD></TR><TR><TD CLASS="quote">alum... is cheaper....</TD></TR></TABLE>
Which is it?
Old Mar 16, 2005 | 09:18 AM
Fab-Works's Avatar
Default Re: Which do you guys prefer :Stainless steel Or Mild tubing for IC piping (m R g S r)
Aluminum bends are a bit more expesive. You have to heat treat it before bending it and heat treat it after bending it. Also cost a bit more in raw state and not any bender can mandrel bend aluminum.
som3on3_10
Apr 8, 2007 12:39 PM
Fab-Works
Feb 13, 2006 05:07 PM
Nutzurchin
Mar 17, 2005 08:01 AM
Fab-Works
Welding / Fabrication
Mar 14, 2005 07:19 PM
WREKONIZE V8 KLR
Jan 17, 2005 05:05 PM
