need a set of shocks for the rear that can handle ground control 1000 lb springs.
The Ground Control dual adjust shocks/struts are nice as are the Strange Engineering shocks/struts.
I, myself am trying to decide between those 2 options.
Both are made for the CRX.
You can get the Ground Control Advance Design Shocks/Struts from Ground Control or any Ground Control distributor.
The Strange Engineering SHocks/Struts can be Purchased direct from Strange Engineering or from any Strange Engineering distributor.
Kens Kustom Chassis is the only Strange Engineering dealer that I can think of off the top of my head that has anything to do with Hondas
I beleive that Koni would offer a shock that could be revalved for your specific application.
Which year civic? I assume Civic
its for a 89 crx. Sorry about that. I have oem on there now. :D lifetime warranty i usually just change them out after a day at the track. The oem lasted for 2 track days last season and lasted ok on the street for a while but I need something that will last for a while. I know oem is stupid but that is all i had at the time to use.
is the car specifically for drag racing? IM me and i could give you more info on revalving the shocks from Koni and see if that would be something that would suit your needs
unsungfate
Oct 20, 2010 03:55 PM
Skitals
23
Jan 13, 2003 07:03 PM
