sound from right front of car?
Old Mar 15, 2005 | 05:27 AM
sullenht's Avatar
Default sound from right front of car?
ok hear is the deal this just started last week, it is when i am driving its kinda high pitched and raspy. I am getting ready to replace ball joints tie rod ends and bushings starting this weekend. I am not sure if its the wheel barieng or cv joint. the car is a 90 crx si with b16a. I jacked the car up lastnight and spun the wheels and heard nothing so iam guessing it has to be under a load for it to produce the sound. any help would be greatly appreciated. Thanks
Old Mar 15, 2005 | 06:34 AM
sullenht's Avatar
Default Re: sound from right front of car? (sullenht)
anyone I could use some help guy's. Thanks
Old Mar 15, 2005 | 07:35 AM
sullenht's Avatar
help please!
Old Mar 15, 2005 | 07:56 AM
manson's Avatar
wheel bearings usually whine. not sure if its that or not, but if it isn't too much more troulble for you to replace them why not try that.
is it only at high speed or all the time? has it been getting worse?
Old Mar 15, 2005 | 08:20 AM
sullenht's Avatar
Default Re: sound from right front of car? (manson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manson &raquo;</TD></TR><TR><TD CLASS="quote">wheel bearings usually whine. not sure if its that or not, but if it isn't too much more troulble for you to replace them why not try that.
is it only at high speed or all the time? has it been getting worse?</TD></TR></TABLE>
I was thinking that too but whanted to make sure before replacing them someone told me it might be the cv joint but I thought thay only make sounds when you are turning and not in a strieght line.
Old Mar 15, 2005 | 09:18 AM
89hbcivicguy's Avatar
If its a whine or hum it will be the wheel bearing.....if its a clicking sound its your axle
also if its your wheel bearing when ur go around s bends it will go away when u turn one way but it will get louder the other way
Old Mar 15, 2005 | 10:06 AM
sullenht's Avatar
Default Re: sound from right front of car? (89hbcivicguy)
that wouldnt be the sound i am getting its more of a rattle when i am driving kinda high pitch if you can imagin that
Old Mar 15, 2005 | 11:11 AM
blackrex's Avatar
Check and make sure none of your brake pad clips are rubbing your rotor? Only thing I could think of that would make a raspy AND whiny sound under different conditions.
Old Mar 15, 2005 | 11:20 AM
sullenht's Avatar
Default Re: sound from right front of car? (blackrex)
thanks i will look after it stops raining down in texas i will post my findings
Old Mar 15, 2005 | 12:57 PM
2camvtec's Avatar
It's your axle. Mine did the same thing and I replace the axle and it went away
Old Mar 15, 2005 | 04:16 PM
sullenht's Avatar
Default Re: sound from right front of car? (2camvtec)
thanks i will check that too
Old Mar 23, 2005 | 05:10 AM
sullenht's Avatar
quick update put the car on jack stands and put it in 1st gear the car makes no sounds what so ever. Checked the boots on the axles they are fine it only makes the sound if it is on the ground when i drive. I am baffled any other thoughts on what it could be.
thanks to all that have helped so far.
Old Mar 23, 2005 | 08:04 AM
sullenht's Avatar
bump
alexthegrinch
Jul 30, 2008 06:59 PM
FBS
12
Mar 23, 2008 05:37 PM
leoaa777
Jan 5, 2008 06:49 PM
professor poon
11
Mar 15, 2006 07:06 PM
90civic_tio
Feb 9, 2004 06:39 PM
