H23 piston in H22?
Old Mar 15, 2005 | 05:08 AM
RACING INTEGRATION's Avatar
Default H23 piston in H22?
what will the compresion ratio be?
are the H23 pistons as strong as the H22 pistons?
Old Mar 15, 2005 | 10:15 AM
md23vtec's Avatar
Default Re: H23 piston in H22? (RACING INTEGRATION)
Guestimated 9.6:1 compression. I have seen a turboH22 stock block with H23 pistons making 383WHP. It's has been like that for over a year so far daily driven on pump gas . It's all in the tune
Old Mar 15, 2005 | 01:52 PM
T-King's Avatar
Default Re: H23 piston in H22? (md23vtec)
You could do it and it would hold up...... H23a1 9:5:1, H22a 10:6:1
and there both 84mm or 87mm but im pretty shure there 84mm.........but any way yes you could do it.
Old Mar 15, 2005 | 04:41 PM
PirateMcFred's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaLude92 &raquo;</TD></TR><TR><TD CLASS="quote">H23a1 9:5:1, H22a 10:6:1
and there both 84mm or 87mm but im pretty shure there 84mm</TD></TR></TABLE>
Damn dude WTF are you on? 84mm? 9.5:1 compression? *shakes head* that's just not right...
Anyway an H22 with H23A1 pistons all else stock will yield 8.95:1CR
http://www.c-speedracing.com/h...c.php is your friend...
Pirate
Old Mar 15, 2005 | 08:11 PM
StraightCivic's Avatar
can u put a h22 crank in a h23 block
Old Mar 16, 2005 | 01:30 PM
Default Re: H23 piston in H22? (PirateMcFred)
witch rods must I use? H22 or H23?
do I have to machine the H22 rods to fit the H23 pistons?
Old Mar 16, 2005 | 03:12 PM
SKDRCR's Avatar
Default Re: H23 piston in H22? (StraightCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightCivic &raquo;</TD></TR><TR><TD CLASS="quote">can u put a h22 crank in a h23 block</TD></TR></TABLE>
Yes, as long as the h22 crank is from 97' or earlier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACING INTEGRATION &raquo;</TD></TR><TR><TD CLASS="quote">witch rods must I use? H22 or H23?
do I have to machine the H22 rods to fit the H23 pistons?</TD></TR></TABLE>
Whichever crank you use, you have to use the same rods.
no you shouldn't have to machine the rods for the pistons to work
and long as the rods are a press pin fit design
Jdmprelude94
Apr 16, 2005 09:10 AM
T-King
Feb 24, 2005 01:23 PM
H23A1LUDE
Jun 12, 2003 04:43 PM
flip1199
May 9, 2003 08:55 AM
H22Prelude
Nov 17, 2002 08:55 PM
