:::What to Buy What to use. Clutch bleeder kit:::
Old Mar 15, 2005 | 01:01 AM
.water's Avatar
Default :::What to Buy What to use. Clutch bleeder kit:::
I need bleed my Cluch fluid on 00 integra.
i want buy bleeder kit anyone got nice kits? is brake bleeder kit same as clutch bleeder??
http://www.harborfreight.com/c...38053 (is this good?)
or
http://www.matcotools.com/Cata...48111 3rd one
Also when iam using bleeder kit, old fluid is comming out so fluid will go low on tank right? do i just bleed until tank is empty? or bleed little (about to lower level) and fill. again again...
Modified by Chris DC2 at 3:27 AM 3/15/2005
Old Mar 15, 2005 | 02:41 AM
Takumi Fujiwara's Avatar
Default Re: :::What to Buy What to use. Clutch bleeder kit::: (Chris DC2)
When you bleed the clutch, you open up the valve on the slave cylinder. All I did was put a cup under it. Then you need to keep the clutch fluid reservior from draining under the MIN line while you press the clutch. I actually did this myself by filling the clutch reservior as much as I could, then went into my car and pressed the clutch while looking to make sure the clutch fluid didn't go lower than the MIN line. I just used one whole bottle when I did mine.
I don't think you should spend the money on a bleeder kit for this.
Old Mar 15, 2005 | 02:21 PM
.water's Avatar
ya but..i want go easy way..heh i heard that i dont need to press clutch with bleeder kit..
Old Mar 15, 2005 | 06:13 PM
North_Texas's Avatar
Autozone sells a kit.
Old Mar 17, 2005 | 02:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 &raquo;</TD></TR><TR><TD CLASS="quote">ya but..i want go easy way..heh i heard that i dont need to press clutch with bleeder kit..</TD></TR></TABLE>
If I did it, it's pretty damn easy. Maybe I have met my new mentor.
hondaless
Apr 2, 2009 08:58 AM
mr.tom
Sep 20, 2005 03:29 AM
EARLdaSQUIRREL
Mar 1, 2003 03:46 PM
PatrickGSR94
Dec 8, 2002 06:36 PM
