what difference will it make ?
i ordered my hasport motor mounts today along with a b&m fuel pressure regulator with a b&m fuel pressure regulator gauge . he gave me all 3 things for $545 out the door with tax . is that a kool deal ? i was really thinking of just goin with cheaper mounts but i decided i just want to buy one kit that will last me forever
reasone i bought the mounts is because i had a torn drivers side engine mount . so i decided to just get all 3 of them . what difference will i feel with the hasport kit compared to what i have now wich is oem with one torn mount ?
i mean what difference will it make from stock mounts ? i mean i know i bought them to replace the the torn mount along with the other 2 mounts but im askin between stock and the hasport . sorry for the misunderstanding.
you say it rattles like crazy...... what stiffness did you get ?
street , street/drag , or drag ? the ones that i ordered were the street . hopefully those wont rattle as much but also feel more of my power on the ground .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_ek_hatch »</TD></TR><TR><TD CLASS="quote">you say it rattles like crazy...... what stiffness did you get ?
In your case, well in almost every case oem mounts are the only way to go. If you use the car as a daily driver be prepared it wont be the same...well the power and traction will be the same but the car is gonna vibrate to say the least.
Were in the process of a k swap in an eg and when we could we used stock Honda mounts.
Not to knock you but unless money isnt that big of a deal to you I would research future purchases a little more. Good luck!
</TD></TR></TABLE>In your case, well in almost every case oem mounts are the only way to go. If you use the car as a daily driver be prepared it wont be the same...well the power and traction will be the same but the car is gonna vibrate to say the least.
JDM_SOHC
Jul 23, 2014 05:09 AM
strictly.business
May 2, 2006 11:40 PM
