Crower Stage 3 Cams
Might be getting a killer deal on crower stage 3 cams for my type s motor.
Anyone using them? Throughts? Comments? Suggestions?
Searched archives but all that has been posted is "cam specs"; no reviews.
Thanks!
Thanks!
The stage 3's wont make any more power on a K20A or K20A-2 than the Stage 2 3/4.. Even with the stock valve set-up you should be able to get away with revving to 8600rpm. I rev my set-up to 9000rpm on a stock bottom end.
I did rev further and the cams do make power to around 10,000rpm but I spun a big end bearing on my K20A block, so for aquick fix I dropped a K20A-2 block in and away we go..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondog »</TD></TR><TR><TD CLASS="quote">The stage 3's wont make any more power on a K20A or K20A-2 than the Stage 2 3/4.. Even with the stock valve set-up you should be able to get away with revving to 8600rpm. I rev my set-up to 9000rpm on a stock bottom end.
I did rev further and the cams do make power to around 10,000rpm but I spun a big end bearing on my K20A block, so for aquick fix I dropped a K20A-2 block in and away we go..</TD></TR></TABLE>wow i didnt know they were making power to 10k
Crower and Hondata have produced a K-Pro map for the cams aswell now, you'll just have to map the fuel and ignition timing to match your exhaust, intake set-up but I doubt you'd need to change the VTC cam angles...
c1_sleeper
13
Jan 17, 2007 04:36 PM
