Anr Compact vs Profab B-series header
I'm debating on which one to get? I have heard nothing but good things about both headers. Does anybody have any suggestions on which one is the best? Thank you for your help...
i have not yet seen any dyno proven, however i would expect the an-r header to be more proficient in making more power. alot of threads on different headers, doesn't hurt to research
seeing some darn good results from the profabs..only downfall is that is touches the oil pan......upside tho is that its a/c compatable..anr is not.
ya the an-r has mad ground clearance and has a decent gap between it and the oil pan...but as u stated not a/c compatable....the compact version will clear power steering though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">hmmm didnt work with my power steering...
being that an-r designed it for power steering...bs
ive seen personally it fit with power steering
Will fit EF/EG/EK/DA/DC Chassis
Will not clear a/c compressor
Will clear power steering pump
if you read and followed what they say it will fit
http://www.an-r.com/bseriesheader.htm
</TD></TR></TABLE>being that an-r designed it for power steering...bs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">profab will clear ac and prolly ps too
wasn't ur profab a bitch to put in
</TD></TR></TABLE>wasn't ur profab a bitch to put in
it seemed like it was made for a b16 deck height. i mean it fits pretty good once u get the bitch in there...
took some screaming and kicking but it went in hehe.
its very very tight fit overall. you will have to take the ac compressor off for more room. also you have to trim the fan shrowd for the radiator.
it really hugs the pan mines basically touching it. i dont know how this will affect it long run possibly wear a hole? i dont know but i will take the header off when i can and check it out. maybe mod the pan alittle to fix the problem other then that theres no real problems with the header. seems to make power on my motor so i gess it works?
Sales@Bisimoto.com
News and Announcements
26
Dec 9, 2011 01:49 PM
AllMotor12s
85
Sep 2, 2006 06:27 AM
