defroster help!!!!
Old Mar 14, 2005 | 04:32 PM
chue_li's Avatar
Default defroster help!!!!
i have an ek hatch and the problem is my defroster doesn't work. the fuse is good, all the wires on the window is in tact, i have already bought a new switch and still doesn't work. so what could be the problem?
Old Mar 14, 2005 | 05:19 PM
Lmgrcivic's Avatar
Default Re: defroster help!!!! (chue_li)
I would like to know also I have the same problem with my coupe
Old Mar 14, 2005 | 06:32 PM
Brian Hinson's Avatar
Could be a possibility that someone has once had window tint on it, and then had it removed improperly, causing you to lose you rear defogger. It will appear that the lines are still in tact but they really arent.
Thats my only guess, an if im right, then I have no clue how to fix it...I guess your only resort would be installing a new rear glass
Old Mar 14, 2005 | 07:06 PM
rathabun's Avatar
Default Re: defroster help!!!! (Brian Hinson)
if u read the owner manual, it say not to clean the rear window from the inside with any think harsh. if u did that, u can damage it. i only use water
ITR #1202
Honda S2000
18
May 26, 2010 04:09 PM
dj-t
Feb 8, 2009 07:51 PM
UgP
Jun 16, 2007 10:51 AM
Dan GSR
Sep 17, 2002 11:35 PM
