DOHC ZV valve seals
Old Mar 14, 2005 | 03:10 PM
gregv's Avatar
Default DOHC ZV valve seals
hello all
what is the correct (domestic) part to get for the valve seals on my 1991 JDM DOHC ZC?
Seeing as I can't get in touch with Honda of Japan, I am hoping someone here has the answer. You would think that as long as the valve stem is the same dia., then seals from a D16A6 OR D16A1 would work, no?
any info appreciated
greg v
Old Mar 14, 2005 | 03:13 PM
mr_valentino20032000's Avatar
Default Re: DOHC ZV valve seals (gregv)
have you been introduced to http://www.thezcr.com? its a great site for the ZC and they have ALL the info on the ZC. but off the top of my head i don't know what you need
Old Mar 14, 2005 | 06:02 PM
gregv's Avatar
Default Re: DOHC ZV valve seals (mr_valentino20032000)
hello Mr. Valentino
I looked through the site and the info I needed wasn't posted, but I did start a thread about it. Thanks for the link.
cheers
greg v
Old Mar 14, 2005 | 06:17 PM
zcrxt's Avatar
i just ordered some of these. I got the ones for an 89 integra. The headgasket and other internal parts are replaceable with the intgra parts, so i assumed that they would be the same also. I am replacing them sometime this week.... so i guess i will find out.
Ben
Old Mar 14, 2005 | 06:35 PM
gregv's Avatar
Default Re: DOHC ZV valve seals (zcrxt)
thanks ben
keep me posted, I would be more than interested to hear how it works.
cheers
greg v
Old Mar 14, 2005 | 10:06 PM
Nerologic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcrxt &raquo;</TD></TR><TR><TD CLASS="quote">i just ordered some of these. I got the ones for an 89 integra. The headgasket and other internal parts are replaceable with the intgra parts, so i assumed that they would be the same also. I am replacing them sometime this week.... so i guess i will find out.
Ben</TD></TR></TABLE>
exactly
Old Mar 15, 2005 | 05:14 AM
spongerlbc's Avatar
You are correct that you need them for an 89 Integra, but there are also 2 different kinds for the 89 Teg depending on the serial number (I believe we need them for the lower range). I used Felpro Valve Stem Seal SS72632-1 and it worked great.
Old Mar 15, 2005 | 05:25 AM
WhatThaFrig's Avatar
Default Re: (spongerlbc)
I used a headset for an 89 Integra. Worked good for me. I believe it was a Fel-pro.
ex voto
Aug 31, 2005 08:14 PM
gregv
Mar 15, 2005 06:39 AM
crx(gator)
Feb 9, 2003 02:54 PM
SiRWannabe
Jan 26, 2003 10:21 PM
