coolant flow
hi everyone
i just put in a 98 type r motor and put in a new radiator. I filled it and am noticing the coolant isn't flowing. the thermostat works, the pump looks good its not seized or anything and i can fill up the motor and literatly "blow" the coolant through the entire system. However say i take off both hoses from the radiator and fill them and the motor the coolant doesn't good anywhere with the motor running it just sits there, Help please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BadRelge45 »</TD></TR><TR><TD CLASS="quote">it would get like to just below the middle, perfect. but if it take off the hoses shouldn't i be getting sprayed with coolant</TD></TR></TABLE>
Yeah... so you are saying your car warms up to temp (the temp needle raises and holds steady)... then you take off the radiator hose and you don't get sprayed with coolant?
Weird man... the system should pressurize once the engine warms up a bit...
cheeksnme
Dec 27, 2006 09:48 AM
DRKSol
Jun 6, 2005 04:51 AM
