4th gen sturt rod
does anyone know where i can get an adjustable strut rod for my 92 SI. The strut rod is used to adjust the caster of the wheel (front to back). it connects from the bottom of the strut to the frame. my frame got slightly bent and the only way to properly line up the caster is to get an adjustable strut rod.
i already had the frame aligned the best it can be and i have to get and adjustably sturt rod
any help would be greatly apprecitated
Modified by ludeman292 at 3:07 PM 3/14/2005
Modified by ludeman292 at 10:49 PM 3/14/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeman292 »</TD></TR><TR><TD CLASS="quote">does anyone know where i can get an adjustable strut rod for my 92 SI. The strut rod is used to adjust the caster of the wheel (front to back). it connects from the bottom of the strut to the frame. my frame got slightly bent and the only way to properly line up the caster is to get an adjustable strut rod.
Modified by ludeman292 at 2:37 PM 3/14/2005</TD></TR></TABLE>
No it's not. The best way to line up the caster is to get your frame aligned.
ArchAngel Sabastian
Sep 1, 2003 04:10 PM
