GC coilover model 4245.1
I'm comfused!
the direction said place the O rings then the spit sleeve and then the adjustable sleeve?
It don't fit on the strut?
The only way that fit is the adjustable sleeve over the O rings. Not using the split sleeve.
Help!
strut/shocks is kyb agx
Help!
I had the same problem when I changed to them shocks. You can wrap the strut with a band of electrical tape under the rubber sleeve until you get a snug fit when you slide the aluminum sleeve on.
But the back will not fit with just the split sleeve and the adjustable sleeve only?
Do I really need that split sleeve?
I'm think just use the O-rings and the adjustable sleeve, and forget the split sleeve?
micah_m
Suspension & Brakes
21
Feb 25, 2010 12:44 PM
DuongBros.
Suspension & Brakes
Nov 13, 2008 08:36 AM
BigZ88
Jul 14, 2003 04:19 AM
