tranny problem
Old Mar 14, 2005 | 11:52 AM
Vince909's Avatar
Default tranny problem
i'm getting a 96 accord from one of my cousins and only known problem right now is that the tranny won't go to 5th gear. instead of buying a whole new tranny is there something i could do to fix the one i have now ?
thanks for the help
Old Mar 14, 2005 | 12:42 PM
tr3-2001SE's Avatar
Default Re: tranny problem (Vince909)
I am assuming you are talking about a automatic transmission.
I am somewhat unfamiliar with Honda Transmissions. I do drive cars to 300,000+ miles so I have had some transmission problems. It seems you have two choices. The first has worked best for me. That choice is a good used transmission. This is a transmission from a low milage wrecked car. I purchase one for my Mercedes Benz 300D for 800 dollars and installation was 200 dollars. You need a wrecking yard you can trust and offers a warranty. Usually only 90 days but that is enough to make sure it works properly.
The transmission for the honda accord up to 97 seems to be a good one so Hopefully you could find a good used one. Repairs to a transmission are very expensive and unless you find an excellent shop( fairly rare) to do the work you can have problems later. There is a third option which is a rebuilt transmission with a good warranty. I would think a least a one year warranty. This is usually a lot more than the used option but if you plan to keep the car for ever maybe the way to go.
Old Mar 14, 2005 | 12:46 PM
Razor's Avatar
Default Re: tranny problem (tr3-2001SE)
hes most likely talking about a 5-spd manual. automatics don't have 5 gears.
Old Mar 14, 2005 | 12:47 PM
kniob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr3-2001SE &raquo;</TD></TR><TR><TD CLASS="quote"> I am assuming you are talking about a automatic transmission.</TD></TR></TABLE>
aren't automatic transmissions in accords only 4spd? so why would it have trouble going into 5th? ... if it doesn't have a 5th?
Old Mar 14, 2005 | 12:48 PM
JimBlake's Avatar
I believe it's a cable shifter, so you can check the cables going from the shift lever to the transmission. Maybe something's loose or something simple like that?
Old Mar 14, 2005 | 07:30 PM
kseriesDC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vince909 &raquo;</TD></TR><TR><TD CLASS="quote">i'm getting a 96 accord from one of my cousins and only known problem right now is that the tranny won't go to 5th gear. instead of buying a whole new tranny is there something i could do to fix the one i have now ?
thanks for the help</TD></TR></TABLE>
sucks..
curthonda777
Jun 24, 2017 03:13 PM
98bucket
Sep 7, 2010 04:18 AM
dk015
Mar 24, 2007 07:03 AM
cjpacheco93
Feb 27, 2007 08:31 PM
