Need help. Distributor is new and working but no spark
Old Mar 14, 2005 | 11:21 AM
Tanaka69's Avatar
Default Need help. Distributor is new and working but no spark
well..
i have 98 ex that was theft recovered. i replaced all the harness already.. engine cranks and plenty of fuel but no spark. need help
Please bump
Old Mar 14, 2005 | 11:23 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Need help. Distributor is new and working but no spark (JT69SP)
First, check all of your grounds, and make sure your ECU is giving the correct output.
Old Mar 14, 2005 | 12:39 PM
Tanaka69's Avatar
Default Re: Need help. Distributor is new and working but no spark (JDM_Ej)
nope checked it thaks... still won;t fire
Old Mar 14, 2005 | 01:15 PM
gobblebox59's Avatar
dude my car went insano and died about a month ago, i had no spark for 3 weeks while i tried to figure out why it wouldnt work at all, i tried 2 dizzys, and even checked them to make sure they worked and still my car had no spark so i towed hurrr to my local shop and they found my ECU was seriously fried and i had a severly clogged or busted injector so they replaced everything with stock stuff and they still had problems getting it started for hours after installing everything, hope this helps some cuz when it happend to me i was stumped for 3 weeks!
Old Mar 14, 2005 | 02:25 PM
civictildeath's Avatar
Default Re: Need help. Distributor is new and working but no spark (gobblebox59)
could be the Ignition Control Module. find someone that has the same style as yours and try it
Old Mar 14, 2005 | 07:05 PM
Tanaka69's Avatar
Default Re: Need help. Distributor is new and working but no spark (civictildeath)
my injectors are clean... compressions are good just no spark... i swap distributor with a friend and it worked on his car..
ICM where is that at?
Old Mar 15, 2005 | 07:42 AM
Tanaka69's Avatar
anyone? have any idea
hondachris1994
Aug 15, 2017 10:58 AM
JeremyG
Honda CR-V & Element
Jul 2, 2014 07:25 PM
fatjoe2174
Jun 6, 2005 01:53 PM
boostedcivichatchbacksi
Jul 22, 2004 02:29 PM
almighty
May 5, 2004 04:53 PM
