Raising Integra Redline
Old Mar 14, 2005 | 09:43 AM
WH0R3nEF9's Avatar
Default Raising Integra Redline
I've got a 94 GSR with a turbo kit and I'm installing a hondata kit soon. Is there any way i can raise my redline without building my head or blowing it up? Do I need an ecu chip? What should I get? Please help!
Old Mar 14, 2005 | 10:29 AM
uzabatty's Avatar
Default Re: Raising Integra Redline (1SiKTeG)
I'd do a search for "increase redline" or something like that
Old Mar 14, 2005 | 11:01 AM
stareatsun's Avatar
To raise the redline safely, you need better cams to make power higher, also a built bottom end might help keep things together. You keep going past stock redline with a stock motor however, your time will come.
Old Mar 14, 2005 | 11:05 AM
BlownVR's Avatar
Default Re: (stareatsun)
well you can adjust it with hondata, i believe it takes out the rev limiter, so you can safely take it to like 8600.
Old Mar 14, 2005 | 11:23 AM
G-bonic's Avatar
Hijacked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKTeG &raquo;</TD></TR><TR><TD CLASS="quote">I've got a 94 GSR with a turbo kit and I'm installing a hondata kit soon. Is there any way i can raise my redline without building my head or blowing it up? Do I need an ecu chip? What should I get? Please help!</TD></TR></TABLE>
Raising the Redline and ur car being turbo w/o chaging some of the internals will mess up ur engine specially if u go over 10 11 and up psi, but to be safe if i were u if u got stock internals just dont go over 10psi to be safe, but u gonna have to get ur car tuned perfectly fuel/air/ratio etc.... find some local tuner at ur place and ask some advise they should kno more..
Old Mar 14, 2005 | 12:11 PM
DA-nteg's Avatar
Default Re: Raising Integra Redline (Stock_LS)
valve springs are a must...
Old Mar 14, 2005 | 08:45 PM
WH0R3nEF9's Avatar
Default Re: Raising Integra Redline (DA-nteg)
Im not quite ready to build the head and dont want to blow it up, so maybe i'll wait for a while. Thanks
CivicxTree754
Engine Management and Tuning
16
Mar 16, 2011 08:30 PM
jdmlude87
Oct 26, 2008 08:10 AM
Markland Photo
Oct 17, 2006 12:32 PM
SiRLudeVtec
Mar 14, 2005 10:20 AM
TolnaPunk
Jan 3, 2004 05:14 PM
