VAFC PROBLEM ON ACURA CL SAME AS 94-97
Old Mar 14, 2005 | 09:24 AM
CIVICHB1's Avatar
Default VAFC PROBLEM ON ACURA CL SAME AS 94-97 ACCORD
I HAVE A VAFC ON MY 98 ACURA CL AND I REALLY DONT HIT MUCH POWER UNTIL LIKE 4000RPM AND I WAS WONDERING IF ANYONE WITH A 94-97 ACCORD HAS HAD THIS PROBLEM BEFORE WHILE USING THE APEXI VAFC. SINCE MY CL IS THE SAME AS AN ACCORD. SO ANY INFORMATION WILL BE GREAT THANKS IN ADVANCE.
KEVIN
Old Mar 16, 2005 | 03:50 AM
CIVICHB1's Avatar
Default Re: VAFC PROBLEM ON ACURA CL SAME AS 94-97 ACCORD (CIVICHB1)
HELP FROM ANYONE?
Old Mar 17, 2005 | 07:29 AM
twkdCD595's Avatar
first off... do you mind the caps (3rd key up on the left... ).
do you have a check engine?
are you trying to say it seems more sluggish coming up through the rpm?
what are the various setting values at in the vafc?
what is your engine code on that 98?
give us some more details.
Old Mar 17, 2005 | 08:06 AM
FG Two's Avatar
i dont think the vafc was made for that engine, ive read on other threads that it doesnt work properly on the f series
Old Mar 17, 2005 | 09:13 AM
Stew Pidasso's Avatar
Default Re: VAFC PROBLEM ON ACURA CL SAME AS 94-97 ACCORD (Phat4drVtec)
That's what apexi says but it works on those. Check all of your setup setting on the VAFC. Maybe reset it and reprogram the setting back in.
Old Mar 18, 2005 | 03:58 AM
CIVICHB1's Avatar
do you have a check engine? no check engine
are you trying to say it seems more sluggish coming up through the rpm? its sluggish until it hits about 4000rpm then after its like a whole different car
what are the various setting values at in the vafc? vti-3200 vto-4200
what is your engine code on that 98?f23a1
so if you know anything that people have to done to fix this problem or an idea it would be greatly appreciated or you just might see it for sale soon.
Kevin
(sorry for the CAPS)
Old Mar 19, 2005 | 12:43 PM
CIVICHB1's Avatar
ttt
walo
Dec 16, 2009 02:32 PM
_VTi_
May 2, 2005 09:43 AM
SonicDark
Aug 5, 2001 10:00 PM
