flex-a-lite fan for an EF with a/c. do they make one? any other manufacturers?
Sup H-T members!!
I was wondering if anyone knows if flex-a-lite makes a fan kit for an EF with a/c.
OR
Does anyone know of a manufacturer that makes a "slim" fan kit for this application?
I'm in the process of swapping out my D16 for a B16 but I want to keep my a/c and clean up some of the clutter in the engine bay. Any input is greatly appreciated. Thanks in advance to y'all.
OR
I have not seen a kit specifically made for the ed and ef but there have been people who just modify the eg kits to work.
what modifications would you need to do? note that this is an ef with a/c (two fans). thanks for the input!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_VTEC »</TD></TR><TR><TD CLASS="quote">what modifications would you need to do? note that this is an ef with a/c (two fans). thanks for the input!!</TD></TR></TABLE>
I also want to know...As I will keep my A/C when I swap
has anyone tried using a DC flex-a-lite fan kit? its much longer and has two fans!!! anyone??
it would be nice if they (flex-a-lite) made a kit for this application. i want to keep my car strictly a street car...a.k.a. all the creeature comforts!!!
TTT
any more info guys and gals???
TTT
true...it may be a little pricey, but, I'm going for that "clean" look. I like the fact that it's thin and clean looking. I think it would help my already cluttered engine bay...especially in black!!
anyone try using the DC kit on an EF??? Am I gonna have to try it???
Bump for more info.
Bump for more info.
i need a new condenser fan in my hatch, and i think im just going to buy a fan from jegs.com after i measure it out. jegs has a lot of aftermarket fan choices, check them out..
I work for a Volvo dealership we have a ton of recalled electric fans. just cut off the black box and run it off the two wires to the motor. You have to figure out how to mount it but we are just tossing them so you can get one for free
id like to know this as well
my fan is busted to ****, and id like a thin aftermarket one that fits, single fan no A/C here.
bump for something thats the right size!
bump....cause id like to know what slim fan options we have for A/C condensor since ill be putting a turbo in mine.....someone on this board is selling slim fans for like 60 but im not sure how they fit or mount.....someone must have answers and pics?
Dual 12" flexalite fans: $209.88
http://store.summitracing.com/...w=sku
you could make your own brackets to fit it out of aluminium and then wire it in to your stock wiring.
the benefit of these fans over most autoparts retailers fans is that they flow more cfm. the max cfm i found out of any single fan at a local autoparts store was around 900 cfm. Each fan in this kit flows at 1250 cfm.
i am running one of these on my eg radiator and it works great.
