help 96 dx to ex manifold change
You can use the same IACV as you have now since you won't change the ECU. Just cover up the holes on the back of the EX intake manifold for the IACV. The IACV is on the throttle body for the DX's instead of the manifold.
You'll need to somehow modify your throttle plate or get an EX one, as well as the holder for the throttle cable that mounts onto the manifold. Everything else is straightfoward if I remember right. Probably get 4' or so of 1/4" I.D. fuel hose for extending the PCV Valve line, and maybe a coolant line or two.
There might be a write-up somewhere on here for it too.
allablur
Aug 19, 2004 07:34 AM
sparco civic97
Mar 24, 2004 11:11 AM
1996civicDX
Mar 31, 2003 11:41 AM
romeo619romeo
Mar 25, 2003 10:57 PM
