B18b1... Is this Right? I cant get my TDC exact... Please take a look and help
Old Mar 14, 2005 | 08:08 AM
Jwbetley's Avatar
Default B18b1... Is this Right? I cant get my TDC exact... Please take a look and help
I am weeks away from dropping in this b18b1 into my eg civic. I have just about everything I need. I put new seals, gasket, studs, water pump, and timing belt.
Now, I am having a lot of trouble with the belt. I cant seem to get the TDC to line up when the cams are at 12oclock perfect. It is about a half inch off, but if i try to fix it by adjusting the belt over a notch, It goes a 1/4 inch in the opposite direction. I have OBX cam gears for future tuning, which are both set at 0.
Here are some pictures, will someone give me some feedback.
Thnks in advance for your comments
Old Mar 14, 2005 | 08:15 AM
sleepin91teg's Avatar
Default Re: B18b1... Is this Right? I cant get my TDC exact... Please take a look and help (Jwbetley)
Sometimes stupid **** like this happens...since its on an engine stand, pull it apart again(timing belt) get the crank to TDC, and look down the #1 cyl hole to make sure it really is TDC. Then put the belt on, follow a haynes, helms or chiltons manual, they are very specific and give pictures also...its not hard to do, just make sure its done right...last thing u wanna do is blow it up or bend valves...Hope i can help
Josh
Old Mar 14, 2005 | 08:18 AM
Also put the stock cam gears on just to see if u can get it in time...then if u can get it in time...go head and put on the OBX gears...just had a brain fart on that one
Old Mar 14, 2005 | 08:22 AM
ssbpturbohatch's Avatar
Default Re: B18b1... Is this Right? I cant get my TDC exact... Please take a look and help (sleepin91teg)
if i'm not mistaken on the top side of the cam when they are at 12 oclock there should be holes you can stick a screwdriver in to keep them in place and to help make sure they are in fact at 12 oclock, should be located right behind the cam gears just a bit then just line the crank up at tdc and it should work with no problem. hope that helps
Old Mar 14, 2005 | 08:25 AM
Default Re: B18b1... Is this Right? I cant get my TDC exact... Please take a look and help (ssbpturbohatch
Good call SSP, the hole will line up in the cam, through a hole in the cam caps.
Old Mar 14, 2005 | 08:39 AM
Old Mar 14, 2005 | 08:46 AM
Jwbetley's Avatar
I guess I can put the stock gears on and try to get it right. Is it possible I have the wrong timing belt or something... I am getting real aggrivated. Also, would a 1/4 inch make a big difference?
Old Mar 14, 2005 | 09:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jwbetley &raquo;</TD></TR><TR><TD CLASS="quote">I guess I can put the stock gears on and try to get it right. Is it possible I have the wrong timing belt or something... I am getting real aggrivated. Also, would a 1/4 inch make a big difference?</TD></TR></TABLE>
definitly try with the stock gears, wrong belt is highly unlikley if you got it at a parts store brand new but anything is possible, 1/4 inch off make a diff., maybe-maybe not?
Old Mar 14, 2005 | 01:08 PM
Jwbetley's Avatar
worst comes to worst, I guess I can just tune it out with the gears.
Old Mar 14, 2005 | 02:42 PM
Jwbetley's Avatar
OK, i went back, and tried again. I put the old gears on, but it made no difference. I Then put the obx's back on, and once again, no difference... Is there any reason for this? I am so confused.
Here are some recent pictures. I have the crank at TDC, but the gears are not perfectly alighned.
Do these gears look to be alighned enough to run normally? Will the difference make a difference?
Please help, Im lost.
Old Mar 14, 2005 | 03:42 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jwbetley &raquo;</TD></TR><TR><TD CLASS="quote">Do these gears look to be alighned enough to run normally? Will the difference make a difference?
No way.
You want the inside marks point right at one another.
Old Mar 14, 2005 | 05:09 PM
Jwbetley's Avatar
What should I do? How can I fix them so that they line up... Its not a matter of slipping the belt over a notch... there is something else wrong. I am lost. anyone else think they can help?
Old Mar 14, 2005 | 05:45 PM
illestrolla247's Avatar
yea i thought on the DOHC engines the 2 lines on the gears were supposed to be pointed towards eachother in the middle soooo the left ones at 3 oclock and the right at 9 oclock
someone correct me if im wrong
Old Mar 14, 2005 | 05:50 PM
BAH double post i feel like a newb
Old Mar 14, 2005 | 05:58 PM
Jwbetley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illestrolla247 &raquo;</TD></TR><TR><TD CLASS="quote">yea i thought on the DOHC engines the 2 lines on the gears were supposed to be pointed towards eachother in the middle soooo the left ones at 3 oclock and the right at 9 oclock
someone correct me if im wrong</TD></TR></TABLE>
What do you mean? I have never heard of that on a honda motor. Even the stock gears have the 12oclock arrows, and the woodruff key is at 90 degrees.
Im certainly not an expert. I do need help.
Old Mar 14, 2005 | 06:23 PM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jwbetley &raquo;</TD></TR><TR><TD CLASS="quote">What should I do? How can I fix them so that they line up... Its not a matter of slipping the belt over a notch... there is something else wrong. I am lost. anyone else think they can help?</TD></TR></TABLE>
It looks like the intake cam is off by a tooth.......With that said why dont you slide the belt off with the crank lined up with the mark, then line up the cam gears and slide the belt back on...........Its as simple as that. Basically just move the intake cam clockwise until it lines up with the exhaust cam, which is about a tooth off. Then everything should line up.
Old Mar 14, 2005 | 06:53 PM
Combustion Contraption's Avatar
Wrong waterpump/number of teeth for that timing belt/setup?
Old Mar 14, 2005 | 07:28 PM
1993sir05's Avatar
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Wrong waterpump/number of teeth for that timing belt/setup?</TD></TR></TABLE>
second this!
Old Mar 14, 2005 | 08:36 PM
Default Re: (1993sir05)
Take the belt off the cam gears...put the screw driver in the cam hole so it wont move, when you have them lined up, put slip the belt over....make sure u loosened the tensioner bolt so it will lose tension...this really isnt that hard...about the waterpump, any bseries will work as far as teeth go...
Old Mar 14, 2005 | 09:22 PM
EG6 SiR's Avatar
Default Re: (sleepin91teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepin91teg &raquo;</TD></TR><TR><TD CLASS="quote">...about the waterpump, any bseries will work as far as teeth go...</TD></TR></TABLE>
No.....only the B-series vtec waterpumps will work. Non vtec waterpumps have a different number of teeth
Old Mar 14, 2005 | 09:28 PM
Edit: oops.
Modified by LsVtec92Hatch at 6:40 PM 3/15/2005
Old Mar 14, 2005 | 11:43 PM
V-SPEC 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">The above post is correct. VTEC water pumps have less teeth to slow the spin of the pump at higher RPM.</TD></TR></TABLE>correction, the vtec water pump have 22 teeth and the non vtec pump has 19 teeth.
Old Mar 14, 2005 | 11:47 PM
V-SPEC 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jwbetley &raquo;</TD></TR><TR><TD CLASS="quote">OK, i went back, and tried again. I put the old gears on, but it made no difference. I Then put the obx's back on, and once again, no difference... Is there any reason for this? I am so confused.
Please help, Im lost.</TD></TR></TABLE>what do you mean by old gears on? You mean stock gears right? if so, what water pump are you using and what timing belt are you using from? did you have the 2 cam holes line up to the cam plate?
Old Mar 15, 2005 | 02:40 AM
MenaceL.A.671's Avatar
dayum i have the same problem too... my aem cam gears dont line up... and i have oem gsr water pump and gsr timing belt?? and by the way i have a ls/vtec... das weird...
Old Mar 15, 2005 | 06:26 AM
PrettyLude's Avatar
compare it to the factory cam gears and see, there is a possiblity that the marks on the cam gears are wrong
