Integra brake conversion ?'s
Ok, so I got my 90 Integra brake conversion for my 88 CRX. I have been told I should just swap the entire suspension. So i figured I would go ahead and replace the rear trailing arm bushings in the process. My question is should I use the bushings for the CRX or get them for the Integra? Couldnt find any info while performing a search. Thanks in advance...
-Adam
-Adam
I would get them for a CRX might as well. They're pretty much the same thing. I am not sure if it was the DA Teg, but that bushing was a little different. Let's see if someone else knows what I'm talking about.
the intergra has a bigger rear bushing...you "cant" install them into the crx trailing arm by itself...you have a couple of extra steps to install it...do a search for member "wes v" his website has a how-to and part numbers of the different bushings...
When I did my rear disc conversion on my 1991 hatch, the civic trailing arm bushing kit was to small. I ended up getting the integra da for the trailing arm bushings and the rest was from the energy suspension master civic kit.
All you wanted to know about trailing arm bushings can be found here...
http://www.performanceforum.co....html
i just put 91 integra rear trailing arms on my 91 dx hatch. I put in new bushings from prothane (pn #8-314)for an integra. Be shure you press the bushings out towards the wheel because the sleeve is tapered! press the bushing in from the wheel side. if not you will ruin your trailing arm.
dano670
Feb 14, 2012 06:31 AM
d16trexin
Dec 31, 2008 11:00 PM
iheartmyh0nda
Apr 21, 2007 12:46 PM
EfSedanLove
Nov 7, 2006 06:40 PM
importfan7
Mar 24, 2006 09:55 AM
