Different ECU's
Old Mar 14, 2005 | 06:40 AM
CRXVtecTX's Avatar
Default Different ECU's
I have a 90 Hf Crx and am planning for a d15b vtec to be put in. But am not sure which ecu to use, I read that i can use the p08 or a p28? I planned on going with the p28 but then I read about someone using the p08.. so whats the difference?
Old Mar 14, 2005 | 06:53 AM
Magick211's Avatar
Default Re: Different ECU's (CRXVtecTX)
the p28 is obd1 so you will have to use obd1 dizz also then you will need to pruchase a obd-0 to obd-1 conversion harness
Old Mar 14, 2005 | 07:06 AM
Targa250R's Avatar
be professional
The P28 is specific to the USDM OBD-1 VTEC D16Z6, and the P08 is specific to the JDM OBD-1 VTEC D15B. The P08 also uses 1-wire O2 sensors, while the P28 looks for 4-wire heated O2s.
Old Mar 14, 2005 | 06:37 PM
CRXVtecTX's Avatar
Thanks for all the advice. Much appreciated!
chaos304k
Apr 10, 2019 08:30 PM
khaledbuiltEF
Jul 30, 2011 11:08 AM
dirtyharryhatch
Aug 29, 2009 03:42 PM
