Getting new cams+gears, do I need new vavletrain too?
Old Mar 14, 2005 | 05:21 AM
EM1VtecSi's Avatar
Default Getting new cams+gears, do I need new vavletrain too?
Hey, first off, my car is a 99 SI, with only I/H/E, and new clutch and flywheel. I'm ordering Buddy Club 3 cams, and Buddy Club cam gears, and just wanted to know if these require upgraded valve train. I think my compression is like 10.1:1, completely stock block, and no head-work.
Old Mar 14, 2005 | 05:35 AM
d15bcoupe's Avatar
Default Re: Getting new cams+gears, do I need new vavletrain too? (EM1VtecSi)
Your going to want to get new springs and retainers for sure, if i was you i'd get a 3 angle valve job and one of those nifty metal head gaskets while your at it. Also, I could be wrong but I'm pretty sure its gonna run like poo till you get it tuned, and you probably need to raise the rev limiter to take full advantage of the cams.
Old Mar 14, 2005 | 05:52 AM
Soccerking3000's Avatar
Default Re: Getting new cams+gears, do I need new vavletrain too? (d15bcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15bcoupe &raquo;</TD></TR><TR><TD CLASS="quote">Your going to want to get new springs and retainers for sure, if i was you i'd get a 3 angle valve job and one of those nifty metal head gaskets while your at it. Also, I could be wrong but I'm pretty sure its gonna run like poo till you get it tuned, and you probably need to raise the rev limiter to take full advantage of the cams.</TD></TR></TABLE>
agreed
Old Mar 14, 2005 | 07:02 AM
.Kevin.'s Avatar
a guy on ebay sells p&p heads with upgraded valves,3 angle valve job, springs, retainers for pretty cheap thats what im getting to take full advantage of my camshaft.I would check it out if i were you
pnltnc
Honda S2000
Feb 10, 2007 06:07 PM
SolLesHonda
Nov 7, 2006 06:05 PM
import_king20
Mar 18, 2006 05:08 AM
alfaaay
Jan 15, 2004 05:40 PM
