Serious problems with axles in ZC tranny swap
Have a 91 CRX Si with DOHC ZC motor. The stock trans took a **** so i got a ZC tranny. I have been told to get axles for a 90 integra when using the DOHC ZC tranny swap. Is this correct? My problem is when i put the axles in and go to tighten the nut on the end of the axle i can't turn the wheel. Something seem to be binding. Do i need diff brake? Different hubs, different axles? Does anyone know what the problem is with what i have and why it won't work?
Hmm so if you keep the dust shields on something as simple as that can cause binding?
Did a b16 swap in a friends hf and we were having problems with the hubs/axles and binding.
onefiine69
22
Mar 29, 2005 06:34 PM
onefiine69
Mar 12, 2005 05:08 PM
onefiine69
Mar 7, 2005 06:42 PM
31flavorscivic
Feb 14, 2005 01:08 PM
kanzenr91si
Feb 16, 2004 02:34 PM
