Engine / motor mounts - Mugen vs Spoon vs ES inserts
Old Mar 14, 2005 | 02:42 AM
euG3dc2r's Avatar
Default Engine / motor mounts - Mugen vs Spoon vs ES inserts
Hi All,
In the market for motor mounts and have been reading through the archive with a mixed bag of opinions.
Basically, if money wasn't a factor, which one would be the better option?
1. ES inserts - no doubt they work! but is there a difference between the insert and the mugen replacement? (even if some say that we won't notice the difference). One would logicially deduct that the full replacement would be bigger improvement over stock, but minimal improvement over Stock mounts + ES inserts. True statement?
2. Those who have been on both inserts then replacement mounts - comments?
3. Those who've installed mugen/spoon mounts - comments?
4. Those who've installed mugen/spoon mounts AND ES inserts - comments?
(this one seems to be a turbo R fav)
All theories welcomed.
P.S - no comments on the HAS sports pls They are good though!
Old Mar 14, 2005 | 03:54 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Engine / motor mounts - Mugen vs Spoon vs ES inserts (euG3dc2r)
http://www.jimfab.com
Old Mar 14, 2005 | 04:21 AM
Bbasso's Avatar
Default Re: Engine / motor mounts - Mugen vs Spoon vs ES inserts (ActiveAero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">http://www.jimfab.com</TD></TR></TABLE>
In a few days I'll give a review of them
Old Mar 14, 2005 | 04:35 AM
RagingAngel's Avatar
Default Re: Engine / motor mounts - Mugen vs Spoon vs ES inserts (Bbasso)
I'll wait for pooface to chime in here....
but he has the ES inserts PLUS the prothane mounts.....and wow.... I said it in a previous post...but the vibration is INTENSE....
a 200hp vibrator.....at idle the rear view mirror was next to disposable!
Spikey who frequents this board has Spoon mounts and they were noticeably more liveable..... they aren't as direct as the setup described above.... but I think a happy medium between vibration/performance/value are the ES inserts.
I personally use a single prothane rear mount. That alone has helped alleviate some intense wheel hopping (NOT completely eliminated) at the strip and when looking at my motor on the dyno, the rearward torquing was noticeably less than stock.
Old Mar 14, 2005 | 04:53 AM
Kengs's Avatar
Default Re: Engine / motor mounts - Mugen vs Spoon vs ES inserts (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">but he has the ES inserts PLUS the prothane mounts.....and wow.... I said it in a previous post...but the vibration is INTENSE....
I agree with Pat; the Sp00n mounts are a nice compromise
Old Mar 14, 2005 | 05:18 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">I'll wait for pooface to chime in here....
Ya, but you get used to it. Me likey Wheel hop is all but gone now, but I'm sure the 600 lb springs and bilsteins in the front help a bit too.
Old Mar 14, 2005 | 05:27 AM
furious94ls's Avatar
On my GSR, I had the 2 jimfab mounts. The vibration was unbearable. I had to take them out. Yes wheel hop was eliminated and launches were good. My rear OEM mount was kind of weak though. I think if you get all 5 mounts the vibration would be less.
I replaced them with new ITR mounts 2 front lower and rear. Wheel hop is still gone, launching the same, and no vibration.
Old Mar 14, 2005 | 06:33 AM
BlueR's Avatar
Default Re: Engine / motor mounts - Mugen vs Spoon vs ES inserts (Kengs the "OG" JDM Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kengs the "OG" JDM Junkie &raquo;</TD></TR><TR><TD CLASS="quote">I agree with Pat; the Sp00n mounts are a nice compromise </TD></TR></TABLE>
so are the mugen mounts, harder than stock, not as harsh as the poly inserts
Old Mar 14, 2005 | 06:51 AM
Black R's Avatar
25 Year Member
a 200hp vibrator.....at idle the rear view mirror was next to disposable!</TD></TR></TABLE>
haha, I have the oem mounts + Prothane upper and rear inserts (race disc) + ES lower inserts.
It is certainly livable, and gives you a more "direct" feel to your car.
For those of you who should've purchased a gsr or ls - these aren't for you.
Old Mar 14, 2005 | 07:52 AM
JDM97dc2R's Avatar
ES are have vibrations but its all ok u get used to it at idle..
but they come with the tie thing and i think some of them came out now.. would that affect in anything?
Old Mar 15, 2005 | 03:37 AM
euG3dc2r's Avatar
Great stuff! keep them coming!
Will be awaiting your review Bbasso ... the jim fabs certainly look hardcore
Also just a note for those who don't know...
Spoon is a 3 piece set
Mugen is a 5 piece set.
One thing i forgot to ask.... I see that most comments relate to reducing wheel hop .. which would be the obvious improvement, but would anyone say that it's a worth while track mod?
Old Mar 15, 2005 | 05:50 AM
Default Re: (euG3dc2r)
Most definately it is a worthy track/circuit mod.....
the constant accel/decel that you will be doing will most definately put these on the top of your list.....
I believe Best Motoring did a "tune up" of the Type-R a couple of years ago comparing the engine placement of a used Type-R vs. a new one and they found enough variance to warrant replacing the used up motor mounts....(old sat lower)
I think they argued it would affect how the entire powertrain sat, causing unwanted binding in the axles....but again...this was years ago.....
Old Mar 15, 2005 | 05:55 AM
Flux's Avatar
Default Re: (RagingAngel)
Does anybody know the price for the Spoon mounts? The Mugen set runs a whopping $440...
Old Mar 15, 2005 | 06:14 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euG3dc2r &raquo;</TD></TR><TR><TD CLASS="quote">Great stuff! keep them coming!
Here ya go.
https://honda-tech.com/zerothread?id=1179416
BABY NSX
Oct 8, 2006 09:18 AM
arren123
Aug 5, 2005 05:51 PM
BlueR
Dec 12, 2002 10:13 AM
Black_eh2
Nov 27, 2002 11:53 AM
_unknown_
Jul 11, 2002 08:46 PM
