Piston?
Old Mar 13, 2005 | 08:11 PM
93gsrcoupe's Avatar
Default Piston?
Can you guys give me some estimates on how much you paid to get pistons installed? I'm thinking about getting some oversized JDM ITR's put in my GSR block that has over 100K on it.
Old Mar 13, 2005 | 08:58 PM
ExospeedAMcrx's Avatar
to do a Proper job, you should take the block out.
Do the following:
1. Bore, hone, deck, the block to match the spec needed for that piston to fit properly.
2. Micropolish the crank
3. Measure for new bearings and thrust washers
4. Install new Oil pump
5. New bottom end gasket set
6. and final assembly
IT would run you about $1300-1600 with the pistons and all the new parts.
You will also need a new timing belt, head gasket and if you want, a new timing belt tensioner.
Anything less would be half assed.
Old Mar 13, 2005 | 09:13 PM
5STAR3's Avatar
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">Anything less would be half assed.
word. i hate seeing people spend soooo much money and them skimp on this or that. just do it all right
Old Mar 14, 2005 | 08:21 PM
93gsrcoupe's Avatar
Default Re: (envision2teg)
Well I just replaced the TB, WP, and head gasket in the summer so I dont have to worry about that. But is that estimate counting the labor involved in a shop taking the block out? I don't have the time or proper tools to be removing the motor myself.
Old Mar 14, 2005 | 08:31 PM
Default Re: (93gsrcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93gsrcoupe &raquo;</TD></TR><TR><TD CLASS="quote">Well I just replaced the TB, WP, and head gasket in the summer so I dont have to worry about that. But is that estimate counting the labor involved in a shop taking the block out? I don't have the time or proper tools to be removing the motor myself.</TD></TR></TABLE>
You should replace the Head Gasket every time you pull the head out.
that doesnt include the removing and installing the engine in and out of the car.
hayden55
Jun 16, 2016 02:51 PM
rico892002
Jul 16, 2007 04:44 AM
PurEvl
Texas -OK -LA (Sales)
10
Jul 1, 2007 11:20 PM
JDM_EK_JOE
May 18, 2006 12:17 PM
krazie1
Feb 9, 2005 08:51 PM
