How do I get the highest compression ratio for LS/VTEC...........
Old Mar 13, 2005 | 07:33 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default How do I get the highest compression ratio for LS/VTEC...........
Ok, I'm mating a GSR head on a stock B18b. What and who makes a head gasket that will get me into 10.5-up compression ratio?
Old Mar 13, 2005 | 08:32 PM
gsr-2nr's Avatar
Default Re: How do I get the highest compression ratio for LS/VTEC........... (D4rk5y3D)
a head-gasket isnt going to yeild the "highest compression" ratio you have in your title. U want high comp you have to get high comp pistons.
Old Mar 13, 2005 | 08:35 PM
LSvtec03's Avatar
Default Re: How do I get the highest compression ratio for LS/VTEC........... (gsr-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">a head-gasket isnt going to yeild the "highest compression" ratio you have in your title. U want high comp you have to get high comp pistons. </TD></TR></TABLE>
ditto.
Old Mar 13, 2005 | 08:40 PM
Haleiwa-Brando's Avatar
Default Re: How do I get the highest compression ratio for LS/VTEC........... (LSvtec03)
I'd like to add that you may have to run 92 octane on this because the higher compression is going to change the 'explosion' properties. Also, you may want a tunable ECU.
If you wanted, with a set of high compression pistions and the proper head gasket you could get your compression close to aroud 12.7:1 to 13.0:1. Though if your going to do this, you need fuel management, and a completely different valve train to make good hp, amongts other things.
Old Mar 14, 2005 | 05:34 AM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default Re: How do I get the highest compression ratio for LS/VTEC........... (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">I'd like to add that you may have to run 92 octane on this because the higher compression is going to change the 'explosion' properties. Also, you may want a tunable ECU.
If you wanted, with a set of high compression pistions and the proper head gasket you could get your compression close to aroud 12.7:1 to 13.0:1. Though if your going to do this, you need fuel management, and a completely different valve train to make good hp, amongts other things.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">a head-gasket isnt going to yeild the "highest compression" ratio you have in your title. U want high comp you have to get high comp pistons. </TD></TR></TABLE>
I am looking for other alternatives as oppose to changing pistons or milling the head since this is a really really really budget buildup. If i had a chance to do it the right way i would go with b16 pistons forged rods etc etc . Since all I really have is the head and ecu i wanted to see what I can work with to bumo up compression a lil more.
Acura-Power
Acura TL, RL & ZDX
May 23, 2024 05:10 PM
LSV_REX
Apr 30, 2005 07:53 PM
ITR_1211
Jan 18, 2004 08:09 AM
CRneXt
Sep 27, 2003 07:56 AM
type autox
Sep 20, 2001 04:44 PM
