SPOON SW388 question
Old Mar 13, 2005 | 05:56 PM
Back2JDM's Avatar
Default SPOON SW388 question
I have a set of SW388 rims
I cracked the lip on one. Its a small crack and it doesn't leak but I was wondering if I could get it welded back together????
If so what are the spoons made of? and how would I go about it?
Old Mar 14, 2005 | 04:44 PM
Naterror's Avatar
I was under the impression that they were made of Magnisium (sp)
Old Mar 14, 2005 | 08:05 PM
eMpAtHy's Avatar
Default Re: (Naterror)
if they WERE made of magnesium..welding it would cause big fire...i think. the fire will burn REALLY bright too. enough to cause eye damage..go to a store and buy magnesium strips and take tongs and hold it above a fire and watch it.
Old Mar 14, 2005 | 09:18 PM
XrcR6's Avatar
SW388's are a forged aluminum alloy. They could be repaired depending on the extent/type of damage. Look up the local wheel repair place(s) in your area and see what they can do for you.
Your SW388's flat black color, as you may know, is actually an anodized finish. So you should point that out to the repairer, to make sure they can get the finish back to original. Anodization is different than painting/powerdercoating most wheel places are used to...
bitek
Feb 14, 2010 04:17 AM
KOALA YUMMIES
Feb 18, 2007 09:36 PM
Back2JDM
Welding / Fabrication
Mar 14, 2005 08:41 AM
98CivicDX
May 3, 2002 12:04 AM
