4th gen prelude died now its not getting spark
I was driving along in my 1995 Prelude VTEC. When I went into second and the car died. We tried getting it started right after and got nowhere. Im getting fuel because im showing pressure on my fuel pressure gauge. I just replaced out stock ignition coil and cap. Car turns over but I get no spark. Anyone have any suggestions?. Ive test cables that connect to coil but not reading proper voltage. Is there something that plugs into wiring before going to coil? I have also checked all fuses and I am not throwing any codes. Any help would gladly be appreciated....
sounds like your distributor is bad. take it out and test it, its an easy test. just spin the bottom end of it when its out of your car, it should spin easily... if its rough or wobbles, then your internal rotor is bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">bad ignitor</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 »</TD></TR><TR><TD CLASS="quote">sounds like your distributor is bad. take it out and test it, its an easy test. just spin the bottom end of it when its out of your car, it should spin easily... if its rough or wobbles, then your internal rotor is bad.</TD></TR></TABLE>
Yep, check both of these
ActiveAero
Sep 16, 2006 11:21 AM
TeamNextGenChris
Nov 16, 2005 03:09 PM
