z6 manifold on multi swap
yes it will work. you did'nt search very well.
https://honda-tech.com/zerothread?id=1087024
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">Find a y8 manifold if you can. </TD></TR></TABLE>
true dat.
true dat.
i thought you said you wanted to do the mpfi swap with the z6 manifold? you don't make sense with what you are asking. what is a manual manifold? what is a multiport swap? you said hurry. what's the hurry if you don't even know what you're asking.
i forgot its called it multi-point, anyways sorry for the bad post apparantly im getting no-where
i have a z6 manifold
i want to put it on my dual-point
the schematics i recieved were to switch it from an SI mani, to a z6.....(i dont have an SI mani, so its 2 steps ahead) oh well i guess im not makin sense
bye
bye
ok so you want to do the "multipoint" swap but instead of using the SI manifold your going to use the z6. Or are u asking if you can use the z6 on the dual point setup. Well the answer for the first one is yes u can use it instead of the si but you have to do the mpfi swap first.
Yes, the z6 works great. I have personally ran both the y8 and z6 manifolds and you cannot tell any difference between the two. Some of the hoses are slightly different between the two, but it is very easy to figure out. You just use the z6 manifold when you do the conversion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x605 »</TD></TR><TR><TD CLASS="quote">alright thanks alot guys, that write up above was very complicated, all i was really wanting to know is the tps compatable with an obd-0 harness? and other sensors?</TD></TR></TABLE>
all sensors are compatible
Flexmyrex
Jul 20, 2003 07:49 PM
