soft brake tubes, clutch.. any soft hose that won't expand ?
Old Mar 13, 2005 | 11:38 AM
menkio's Avatar
Default soft brake tubes, clutch.. any soft hose that won't expand ?
I was re-doing my engine bay and i wanted to replace my hard tube's for the brake lines off the prop valve. I was trying to find out how much psi is in a brake line.. cause i want to replace all the hard lines with soft flex line so i can re-route it to my discrection. Also looks a lot cleaner.
Any idears.. tubes... and brake presure psi
Old Mar 13, 2005 | 11:40 AM
jlacoy82's Avatar
71.192.16.183
Default Re: soft brake tubes, clutch.. any soft hose that won't expand ? (menkio)
What would be really awesome is finding some quick connect hydraulic fittings that would thread into the master cylinder/prop valve and doing it all in small diameter hydraulic lines. Those would definitely withstand the pressures.
Some quick googling comes up with about 1500-2000psi line pressures.
Modified by jlacoy82 at 3:51 PM 3/13/2005
xero_xero
Aug 28, 2012 12:44 PM
danedoremus
May 23, 2012 04:39 AM
Catch
Apr 8, 2011 01:01 AM
Fuster_Cluck
Mar 9, 2008 04:41 AM
Tyree
Aug 12, 2004 09:12 PM
