will 01 itr rims fit on a ep?
Old Mar 13, 2005 | 10:05 AM
jdmekrsi's Avatar
Default will 01 itr rims fit on a ep?
will 01 itr rims fit fine on a 04 si? as for the offset ...will it rub or will it be fine please let me know anyone have pics of what it looks like??(ep w/itr rims gunmetal)
Old Mar 13, 2005 | 12:12 PM
SennaPerfected's Avatar
Default Re: will 01 itr rims fit on a ep? (jdmekrsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmekrsi &raquo;</TD></TR><TR><TD CLASS="quote">will 01 itr rims fit fine on a 04 si? as for the offset ...will it rub or will it be fine...</TD></TR></TABLE>
Not all, but most Acuras and Hondas have a +45mm offset. However, while the offset may be the same, the wheel diameters are usually different, which changes where the spokes lie on the wheel. Case-in-point: The 2001 Integra Type-R wheels you inquire about are 15" x 6" and come with 195/55-15 tires. Your 2004 Civic Si comes with 16" x 6.5" wheels and 205/55-16 tires. Even if the offsets between the wheels you are interested in swapping with were the same, other determining factors as to whether or not the wheel will fit is, the "center bore" and caliper size.
OEM wheels come with a pre-set center bore that is made to rest on the car's hub perfectly. The center bore on the '01 Integra Type-R and '04 Civic Si are probably different. For example, Accords and Civics have the same 45+mm offset, but different center bores.
To satisfy the mass, aftermarket companies usually make wheels with multi-holes and a large center bore (that come with "center rings") to allow that wheel (which was never meant to be on your car) make you believe that it does. A wheel is supposed to rest on the center hub, but many aftermarket wheels put the stress on the studs instead.
Going back to your original question, the Integra Type-R wheels you are interested in will probably not fit your '04 'Civic Si.
Modified by SennaPerfected at 4:51 PM 3/13/2005
Old Mar 13, 2005 | 12:23 PM
jdmekrsi's Avatar
you could not say it any better thanks good post thanks for the info guy!
Old Mar 13, 2005 | 12:51 PM
No problem, we're here to assist each other any way possible.
Old Mar 14, 2005 | 12:59 AM
sleepinEP3's Avatar
Default Re: will 01 itr rims fit on a ep? (SennaPerfected)
my money says theyll bolt up no problem. if they fit under type s brakes id have them on my car already
Old Mar 14, 2005 | 02:09 PM
Mugen Dom's Avatar
Default Re: will 01 itr rims fit on a ep? (sleepinEP3)
i know the EP3R wheels will fit the 04 EP3 with no problem...and the offsets are the same for the 04+ ep3 and the ep3r....i would say they will fit but dunno for sure untill someone tries it out
Old Mar 14, 2005 | 02:23 PM
SKRIMPS's Avatar
Default Re: will 01 itr rims fit on a ep? (JdMK20Ahatch)
hotness
EMphaticONE
17
Dec 15, 2004 06:45 AM
B16A2-EM1
Honda S2000
13
Jun 19, 2003 06:52 AM
ghettols
Apr 12, 2003 08:09 AM
Brian
May 1, 2002 01:27 AM
