Throttle cable ??
GSR TB on skunk2 im, b18c1 engine into 88 crx. which throttle cable would I use ? Ive got my stock one here, and a DA one. Also ordered the ITR throttle cable bracket
agreed....Out of an 89-91 Integ....Should work....If the SI doesn't work it's the Da...if the da doesn't work...you might have to do some junkyard searching...and measure the length you need
