JDM Hood help
Old Mar 13, 2005 | 09:02 AM
JDMEF8SiR's Avatar
Default JDM Hood help
Hey guys well i just bought a JDM hood and i noticed that the hood latch is not fitting in the slot to latch it down so i need to kno what i need to do to get it latched please help me.
Thanx
Old Mar 13, 2005 | 09:50 AM
bagpipe goatee's Avatar
If it's just the pin that doesn't fit in, you just need to adjust the hood.
You don't have the jdm hood with the wide headlights do you? I know its a dumb question, but still.
Adjusting the hood latch is easy, just make sure the hinges are lined up right (for the gaps on the fenders and stuff), then loosen the two screws that hold on the female end of the hood latch, but leave them semi tight so it dosen't slide around on its own. Next, push the hood almost closed (right before it latches). This will push the little female receptacle where its supposed to be, and if the screws weren't too loose, it'll stay there, too. Now you just need to tighted the screws down carefully without moving it.
Old Mar 13, 2005 | 12:24 PM
JDMEF8SiR's Avatar
Default Re: (bagpipe goatee)
I have the JDM hodd with the JDM headlights.
Old Mar 13, 2005 | 12:55 PM
doublethink's Avatar
Default Re: JDM Hood help (JDMEF8SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEF8SiR &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys well i just bought a JDM hood and i noticed that the hood latch is not fitting in the slot to latch it down so i need to kno what i need to do to get it latched please help me.
Thanx</TD></TR></TABLE>
you have to prop the rad support hood with washers to raise it up a bit to make it latch.
heres an article about it:
http://faq.ef-honda.com/index....ng=en
tommy.
Apr 26, 2008 12:11 PM
Ilovemyef9
Feb 22, 2007 07:26 AM
J.nguyen
Apr 28, 2006 12:05 PM
DC*whore
Feb 26, 2005 06:13 PM
kylefakesi-r
Apr 12, 2004 08:13 PM
