keep my turbo or go bigger?
Old Mar 13, 2005 | 12:52 AM
Timmay's Avatar
Default keep my turbo or go bigger?
t3 super 60 .48 a/r
just gonna be running a stock d16z6 with neptune. im looking for about 220-230 whp. Im debating on just selling it and going with a t3/t4 with a .48 a/r then i would have more room to mess around with later.
about how much boost would it take to make 220 whp on the d16?
Old Mar 13, 2005 | 07:39 AM
Timmay's Avatar
Default Re: keep my turbo or go bigger? (Timmay)
bump
Old Mar 13, 2005 | 03:14 PM
Timmay's Avatar
anyone?
Old Mar 13, 2005 | 03:22 PM
turboEGhatch's Avatar
You have room to grow with a Super 60 trim T3 @ 220 WHP, and it will be more fun to drive than any T3/T4. Stick with it, you can always upgrade later.
Old Mar 13, 2005 | 03:50 PM
Timmay's Avatar
Default Re: keep my turbo or go bigger? (turboEGhatch)
about what would be the max a super 60 would do on a d16, can it do 15-20 lbs of boost and still be somewhat efficient?
Old Mar 13, 2005 | 03:54 PM
uglyasscivic's Avatar
That turbo should be fine with a 7200rpm revlimit. It actually sounds fun.
Old Mar 13, 2005 | 04:11 PM
Timmay's Avatar
Default Re: keep my turbo or go bigger? (uglyasscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscivic &raquo;</TD></TR><TR><TD CLASS="quote">That turbo should be fine with a 7200rpm revlimit. It actually sounds fun.</TD></TR></TABLE>
i thought z6 was 7500, but close enough
i wonder if this turbo is capable of 300 whp?
oh and not as fun as 800 whp, i want a ride
Old Mar 13, 2005 | 05:07 PM
PrettyLude's Avatar
that turbo could make it to 300whp but efficient i would highly doubt it, upgrade to a t3t4 so you have room to turn the boost up later
Old Mar 13, 2005 | 05:29 PM
Default Re: (PrettyLude)
The super 60 will make 300 WHP without much trouble, and it will cost him the same to upgrade now, or upgrade 6 months from now, so why not run the super 60 trim and have a more fun car to drive for the time being?
Old Mar 13, 2005 | 05:33 PM
Jared's Avatar
Default Re: (turboEGhatch)
A t3/t4 will have a much easier time with 300whp than a super 60. On my friend's car, B18C, using the t3/t4 that comes with the Turbonetics kit(i think 50 trim, not sure) and a built motor we maxed it out at 14psi at 328whp. Turned the boost up to 17psi, turbo came up faster, but made no more peak hp, so it was pretty much maxxed.
Old Mar 13, 2005 | 07:16 PM
Timmay's Avatar
Default Re: (Jared)
i wonder what the max is on a super 60
like i said ill be doing 220-230 whp for now on the stock z6 bottom it may be a while before a built bottom goes in
Old Mar 13, 2005 | 07:37 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (Timmay)
just curious what exactly is the difference between the super 60 trim vs the regular 60 triM sorry to jack threads buddy btw hellp this guy out
Old Mar 13, 2005 | 08:20 PM
Timmay's Avatar
Default Re: (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">just curious what exactly is the difference between the super 60 trim vs the regular 60 triM sorry to jack threads buddy btw hellp this guy out </TD></TR></TABLE>
like a t3/t04 60 trim?
im not all that good with turbos myself
Old Mar 13, 2005 | 11:42 PM
Timmay's Avatar
so many decisions
Old Mar 14, 2005 | 06:11 AM
mrbsponge's Avatar
the t3 super 60 will make boost so much fatser than a standard t3t4(non ball bearing). i have seen these turbo make awesome boost before 3k rpms, and pull all the way to redline on a sohc, and thats really what you want.
no need for a turbo that makes power at 8500 rpms when you wont be there.
Old Mar 15, 2005 | 10:26 PM
Timmay's Avatar
Default Re: (mrbsponge)
i just wonder what the limit for the super 60 is
i might throw some rods and pistons in and go for 300 whp
Old Mar 16, 2005 | 07:54 AM
Timmay's Avatar
hmmm decisions , decisions
Old Mar 16, 2005 | 08:46 AM
nonvtecD's Avatar
You sure you have a super 60? Just because the trim is 48/60 doesn't make it a super 60, this is a common misconception. For example, my 48/60 is not a super 60. Super 60's are very rare. If you're boosting the stock bottom end, which you are this turbo is fine. It will outlast your stock bottom end for sure.
Old Mar 16, 2005 | 12:30 PM
Timmay's Avatar
Default Re: (nonvtecD)
my buddy i got it from said it was a t3 super 60, he bought it brand new
Old Mar 16, 2005 | 12:41 PM
EJ1 wilcox's Avatar
Depending on the setup it should take about 12-14 psi to get to 230whp with that turbo on the d16z6...
Might as well use the Super 60...
Old Mar 16, 2005 | 05:55 PM
Timmay's Avatar
Default Re: (EJ1 wilcox)
i think i might sell it and get a t3/t04 57 tim with .48 a/r
Old Mar 16, 2005 | 06:07 PM
ive been reading in turbod16 before their site went down and a lot of members had the 60 trim .48 a/r and they were well around 210hp tuned.. if the super 60 has the ball bearing unlike the regular 60 trim then wouldn;t it spool fast? besides you want something that spools at the range you want it to be, not so soon (esp on city driving) nor late since you wouldnt even be able to see those power up where your engine couldnt rev up to
wilcox got the regular 60 trim and on his z6 he said it starts spooling at 3500 rpm and thats good enough for me
Old Mar 16, 2005 | 06:28 PM
Timmay's Avatar
i guess my turbo is garrett
it says .60 on the compressor housing and .48 a/r
it has a weird flange deal for the intake to
Old Mar 16, 2005 | 07:16 PM
platinum00's Avatar
i run a sc50 and i was worried about it being to big.
just got the car back from the street tune, and it's a perfect match for sohc. car rips at only 12psi..
Old Mar 16, 2005 | 07:20 PM
turbohonda's Avatar
Default Re: (platinum00)
Platinum, at what rpm did that Sc50 spool on your single cam? What bore/compression do you have?
